Author Topic: Horn clicking but not beeping?  (Read 613 times)
Offline mikedell
« on: July 31, 2007 - 03:33:01 PM »
oh great ones...
my horn is clicking when on push stering wheel button...
but no horn?
should i go to the horn to investigate or the horn button?
72 Challenger T/A clone Citron Yella!
360 Pistol Grip 4 speed
Bad Azzzzzzzzzzzzzzzzzzzzzzzzzzzz
Offline charger1970
  • Hi, I'm Doug.
Re: Horn clicking but not beeping?
« Reply #1 on: July 31, 2007 - 04:13:22 PM »
It's likely the horns themselves or the relay.
I would start by disconnecting the horns then use a jumper wire from the battery to the horn to make sure they are working. Make sure the horns have a good ground, too.
If they work I would check the relay to make sure it is working.
Hope this helps.  :2thumbs:
1970 Charger 500
2005 Ram Daytona
1989 Dakota Sport convertible
« Reply #2 on: July 31, 2007 - 05:46:33 PM »
Good advice.  :thumbsup:
  A wire from the "+" side of you battery to your horns should make them scream.  :scared: The problem could be your relay on your fuse box, or a poor contact of your horn switch to ground, that is located under the center cap of your steering wheel.
