Thanks Ken,
I tossed in some Summit guages to actually see what my temps are and oil pressure. Before I put them in I used to run at the second line on the temp guage and creep(traffic) up just over it but didn't know what it actually was. Also the oil light never came on.LOL That was all i knew...
Now I know that those readings are 170-175 water temp creeping to 185 in traffic and 30 psi oil hot in gear idleling. Pretty good I thin all is well. It was about 80 here today with some humidity.
I also tossed in a 90 degree adapter I picked up for the oil filter, I need a bigger filter now.LOL I left the factory guages operational by adding a 1/8NPT T-fitting for the oil and adding a new setup for the water. I had to use adapters since the fittings didn't screw into the intake and it would have bottomed out even if it did screw in.
The lights on the guages are added to the dash lamp circuit.
The vibration seems to still be there at 45-55. I have some(alot) play in the slip yoke, so I'm going to have to wait for the new trans and driveshaft I guess....
Tom
By
tdavist, shot with
DSC-P72 at 2008-06-01
By
tdavist, shot with
By
tdavist, shot with
By
tdavist, shot with
By
tdavist, shot with
