THIS IS FOR A BEAUTIFUL 1971 G-440 HP2 COMPLETE 6-PACK MOTOR INSTALLATION DATE IS 7-17 AND THE CASTING DATE IS 5-20-70 AND THE OIL PAN RAIL VIN IS 1C139410 THE BLOCK WAS HOT TANKED AND MAGGED FOR CRACKES IT IS 030 OVER NEW CAM BEARINGS INSTALLED. WITH THE FACTORY STYLE 6 PACK PISTONS BUT THEY ARE FORGED 2355 TRW 030 IT HAS STOCK RODS . IT DOESNT HAVE THE HEAVY 6 PACK RODS THE RODS HAVE BEEN CLEANED AND SHOT PEANED AND THEY HAVE BEEN RESIZED AND ALSO FITTED WITH A NEW SET OF HARDENED ROD BOLTS. THE CRANK HAS BEEN POLISHED IT IS STD MAINS STD RODS THE HOLE ASSEMBLIE HAS BEEN BALANCED IT IS A FORGED STEEL CRANK NEW FREEZE PLUGS IT HAS A NEW 274-480 SUMMIT 6401 CAM AND LIFTERS THAT WORKS GOOD WITH STOCK CONVERTOR I USE THIS CAM BECAUSE IT WORKS WELL WITH THESE COMBINATION AND IT ALSO HAS SOME VACUME SO THE CARBS WILL WORK CORRECTLY IT HAS NEW DOUBLE ROLL CLOYES TIMING CHAIN IT. IT HAS NEW MELLING H.V. OIL PUMP. HAS A NEW SET OF CORRECT 906 HEADS ON IT COMPLETLY GONE THREW NEW SPRINGS AND ALL IT HAS THE STOCK ROCKER ASSY WITH A SET OF USED CHROME MOPAR VALVE COVERS THAT ARE NICE SHAPE THE TOP 6-PACK SET UP IS BRAND NEW NEVER HAD GAS IN IT NEW AIR CLEANER IT IS THE STEEL ONE TOO NEW FILTER THE OUTSIDE IT HAS A SET OF 68 OR 69 H.P.EXHAUST MANIFOLDS THAT HAVE BEEN WILLOBRADED FOR CLEANING AND PAINTED WITH THE POR-15 EXHAUST PAINT ALL NEW PLUG WIRES AND SPARK PLUGS NEW WATER PUMP AND THE PULLEYS ARE NEW NOT CLEANED UP ALSO THE ALTERNATOR BRKTS NEW AND POWER STEERING BRKTS NEW I HAVE PAPER WORK ON MOST OF THIS MOTOR NEW ALTERNATOR IT ALSO COMES WITH A SET OF THE CORRECT MOTOR MOUNTS NEW FUEL PUMP AND NEW DIP STICK TUBE NEW COIL AND IT HAS ELECTRONIC DISTRBUTOR NEW CAP AND ROTOR NEW THERMOSTAT 180 IT IS ALSO FITTED WITH THE CORRECT 402 OIL PAN WITH WINDAGE TRAY THIS WOULD BE A VERY VERY NICE ENGINE FOR A 71 RESTORATION PROJECT I HOPE I COVERED IT ALL.
Asking 6,000..
Feel free to call anytime, 740-943-5311 ask for Nick. Thanks.
