Author Topic: need more help re:horn...  (Read 583 times)
Offline mikedell
« on: August 02, 2007 - 01:02:47 PM »
ok guys...
i took off the sttering wheel horn button, connection looks good...
when i push the horn button the relay clicks... does that mean relay is good?
connections on horn look real good...
fuse is good....
i have not hot wired from battary + to horn yet...
if horns works....????????
if horns dont work ill get new horns????
thanks.... im horny and have no horn!
 :newbie:
72 Challenger T/A clone Citron Yella!
360 Pistol Grip 4 speed
Bad Azzzzzzzzzzzzzzzzzzzzzzzzzzzz
Re: need more help re:horn...
« Reply #1 on: August 02, 2007 - 03:41:03 PM »
I say hot wire the horn, then take it from there.
« Reply #2 on: August 02, 2007 - 04:05:17 PM »
I would say that the relay should be good but you never know without testing it....somehow.
Someone else here was having a similar problem, weak horns, it turned out something in the steering column was the problem..........But fist things first...be sure your horns have a GOOD ground & then hot wire to the battery + post & see if they blow you...maybe solve two problems.
« Reply #3 on: August 02, 2007 - 05:20:42 PM »
I'm sorry for being short in my first post here. If we know the horns are good(the easy part), then we can move back up thru the system. If you hear a click, that is probably good news for the horn switch and relay.
