Author Topic: Power - Trans - shaft and rear..??  (Read 686 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: August 03, 2007 - 05:11:09 AM »
I got a 904 trans after my 340cui, and small driveshaft joins.  If I swap the trans to a 727..???
Will the shaft be to long..???
Will the yoke fit, - trans, and small join..???
Problem is, NO TIRE SMOKE - I got a moth** Fu**** BIG -low stall converter, and aint sure the 904 will stand up to a hi-perf. 340 if I spend money on a high stall converter ...???
Offline tactransman
Re: Power - Trans - shaft and rear..??
« Reply #1 on: August 03, 2007 - 08:32:22 AM »
The driveshaft will have to be shortened around 4 inches,dust cover on the bellhousing is different,filler tube is different and if you get a 727 yoke that uses the small joint you can use the 904 driveshaft. 904 stall converter......hum.......904's are more likely to crack their small converter hub so I would go up to the 727 and be done with it. :cheers:
Terry-tactransman
Union, Mo.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: August 03, 2007 - 02:58:20 PM »
""and if you get a 727 yoke that uses the small joint you can use the 904 driveshaft""
Without shortening it...???
Offline tactransman
« Reply #3 on: August 03, 2007 - 03:17:12 PM »
No ,you still have to shorten it, but you know that the other end will fit your rear end since it is the one you were already using.
Terry-tactransman
Union, Mo.
