Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
70' 4 speed ped assembly
« previous
next »
Print
Pages: [
1
Author
Topic: 70' 4 speed ped assembly (Read 1115 times)
70RAGTOPR/T
Jr. Member
on:
August 03, 2007 - 07:44:12 PM »
Is this the correct 70' 4 speed assembly for an E-Body?
Thanks
Walt
Logged
Lunchbox
Sr. Member
Re: 70' 4 speed ped assembly
Reply #1 on:
August 03, 2007 - 11:44:47 PM »
I would say no, either pedal does't seem to have the right bends in them. Check
www.smsmopar.com
they have good pics of all years of e, b, and a bodys.
Lunch
Logged
70RAGTOPR/T
Jr. Member
Reply #2 on:
August 04, 2007 - 11:53:41 AM »
Thanks Lunch. They look like A-Body peds. I tried to go cheap and I got what I paid for.
Walt
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
August 04, 2007 - 08:58:21 PM »
73 -74 pedals are shaped like that , I bet they will fit no problem
Logged
Carlwalski
C-C.com Expert
Reply #4 on:
August 04, 2007 - 09:09:26 PM »
Off Topic slightly, Neil, I have never driven an older manual car but is the clutch pedal adjustable? Like, is there anyway to increase or decrease pedal height? Closer to the floor meaning quicker shift or pedal time, especially for normal day-to-day driving. Can this be done or once installed that's basically it? I'm not sure if it's controlled by the clutch you use or not? Any insight is much appreciated.
Logged
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
70RAGTOPR/T
Jr. Member
Reply #5 on:
August 04, 2007 - 09:16:40 PM »
Neil .... Thanks for the info. I'll keep them around and use them until I get the correct ped assembly.
Walt
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
August 09, 2007 - 10:10:07 PM »
Carl
yes you can adjust the ratio to achieve faster clutch release , you can shorten the upper lever on the bel crank or increase the lenght of the lower lever or both to change the release speed , but it will increase pedal pressure
Logged
Aussie Challenger
Resident
In Kansas loaded for Drive to West Coast.
Reply #7 on:
August 10, 2007 - 05:58:40 AM »
Carl if you use the Keisler hydraulic kit you can change the master cylinder bore size (larger) and it shouldn't make the pedal pressure any greater.
I don't know what master cylinder Keisler uses so I don't know what would have a larger bore either. However food for thought.
David
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
August 10, 2007 - 10:09:13 AM »
actually using a bigger bore cylinder moves more fluid for the same distance the pedal is moved & will increase pedal pressure as well
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
