Author Topic: Speaker Upgrade  (Read 1545 times)
nivvy
Speaker Upgrade
« on: August 05, 2007 - 10:40:50 AM »
Looking to put some good 6X9's in the car and also what size speakers have you guys put in the kick panels?? thx
Offline GoodysGotaCuda
Re: Speaker Upgrade
« Reply #1 on: August 05, 2007 - 10:42:10 AM »
I put 5 1/4" speakers in my kick panel
1976 Dodge Warlock
Wheel & Tire Specs:Link
nivvy
Re: Speaker Upgrade
« Reply #2 on: August 05, 2007 - 11:09:07 AM »
How big of a hole do you cut in your package tray for 6X9's ?? I have the deluxe package tray with the speaker holes in them??? Did you mount your 5 1/4's to the kick panel or do some fab work??? Might go with the PYLE's cause they are yellow to match my car...any suggestions???
Also whats the difference between 3 way and 8 way speakers???
« Last Edit: August 05, 2007 - 11:22:45 AM by StrOkEr »
Offline Challenger6pak
Re: Speaker Upgrade
« Reply #3 on: August 05, 2007 - 11:42:07 AM »
I would remove the package tray and mount your speakers from underneath without the speaker grilles.  Then reinstall the package tray.  It will look factory with no reason the cut the tray.  If you live in an area with a lot of hot sun, put speaker cloth between your speakers and the package tray to protect them from the sun.
Re: Speaker Upgrade
« Reply #4 on: August 05, 2007 - 11:48:12 AM »
didnt hurt my package tray, and i bought some kick panels with holes in them already for the 5 1/4 speakers. nothing fancy here
1976 Dodge Warlock
nivvy
Re: Speaker Upgrade
« Reply #5 on: August 05, 2007 - 12:15:15 PM »
did you fasten the 5 1/4's right to the kick panel??? I now under the package tray there is a provision to mount the speakers but do you mean mount form underneath the metal provision area??
« Last Edit: August 05, 2007 - 12:34:45 PM by StrOkEr »
Re: Speaker Upgrade
« Reply #6 on: August 05, 2007 - 01:09:31 PM »
Yes, i mounted them straight to the kickpanel. And yes, mount the rears on the underside of the steel package tray
1976 Dodge Warlock
Re: Speaker Upgrade
« Reply #7 on: August 05, 2007 - 01:30:10 PM »
....Or you can mount them on top.
nivvy
Re: Speaker Upgrade
« Reply #8 on: August 05, 2007 - 02:51:41 PM »
goody do your 5 1/4's stick to the metal on the car behind the kick panels???
Mek how did you get them to mount on top??? fasten them to the package tray themself or mount them to the metal part of the package tray and cut a hole in the package tray and put screens?? Im thinking it will sound better if you mount them on top like MEK's ???
Also mounting them on the underside of the metal package tray do you need some sort of cushion between the speaker and metal package tray???
« Last Edit: August 05, 2007 - 02:56:36 PM by StrOkEr »
Re: Speaker Upgrade
« Reply #9 on: August 05, 2007 - 03:19:49 PM »
For what it's worth, I mounted my speakers on top of the package tray. Yes, I did hack away at the package tray to get 6"X9" openings.
« Last Edit: August 05, 2007 - 03:23:31 PM by MEK-Dangerfield »
Re: Speaker Upgrade
« Reply #10 on: August 05, 2007 - 03:31:44 PM »
You do not need a cushion.  If you mount them on top or on bottom of the tray make sure they are tightly mounted.  That way you won't get any sound vibrations or buzzing.
Re: Speaker Upgrade
« Reply #11 on: August 05, 2007 - 03:35:22 PM »
Yep
1976 Dodge Warlock
nivvy
Re: Speaker Upgrade
« Reply #12 on: August 06, 2007 - 01:05:06 AM »
what is coaxil speakers??
Offline Grundy
Re: Speaker Upgrade
« Reply #13 on: August 06, 2007 - 07:37:07 AM »
I bought components. I mounted the fronts underneath the dash facing down, and the tweeters near the bottom corner of the windshield.
Drive it like you stole it.
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: Speaker Upgrade
« Reply #14 on: August 06, 2007 - 08:18:08 AM »
Co-axil = 2 way - woofer and tweeter
Tri-axil = 3 way - woofer, mid and tweeter
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
