Author Topic: Just fooling around...  (Read 2972 times)
Offline purple1
« on: August 05, 2007 - 08:57:41 PM »
... with headlight bezels.
Dave :wave:
Dave
Offline purple1
Re: Just fooling around...
« Reply #1 on: August 05, 2007 - 08:58:47 PM »
Oh, I did work on more than one.
Dave :wave:
Dave
« Reply #2 on: August 05, 2007 - 10:22:13 PM »
WOW...nice work.
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: August 05, 2007 - 10:27:18 PM »
Looking good!!   :2thumbs:
Offline mrob
« Reply #4 on: August 06, 2007 - 08:12:47 AM »
purple,
I straightened an old set of headlight bezels for my 71 R/T like you did, but I wasn't able to get the front edge of the bezels to shine too well after they were straightened. What did you use to polish the front edge of your bezels? Your bezels have a shine almost like the anodized brite dip coating.
Offline purple1
« Reply #5 on: August 06, 2007 - 08:40:08 AM »
purple,
The anodize has to be stripped off before you can polish them. I got some coil cleaner from my friend that does HVAC work. I used the coil cleaner to remove the anodize coating, sanding the anodize between using the coil cleaner. That stuff will etch the aluminum, so you have to wash it off fast, then repeat. Once all (and I mean all) the anodize is off, then you can polish with a buffing wheel on a drill. This one bezel took about 10 hours work alone. Good luck with yours.
Dave :wave:
Dave
Offline IMNCARN82
  • LeDZeP
« Reply #6 on: August 06, 2007 - 09:09:11 AM »
WOW...nice work.
:iagree:     very impressive work!
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline purple1
« Reply #7 on: August 06, 2007 - 09:37:59 AM »
Thanks guys, the other two are now ready for paint. The second set should turn out even better than the first.
Dave :wave:
Dave
Offline DAYLEY/CHALLENGER
« Reply #8 on: August 06, 2007 - 09:56:05 AM »
Looks great there Dave.  What did you use to remove the dings from  the rolled edges.?  I have a couple of places in the windshield trim that need more work than what I have done so far.  Did you use some sort of roller device to smooth the surface area.   Stainless will be harder to do but give up your secret man................... :bigsmile: :bigsmile:
Dave or David
Offline purple1
« Reply #9 on: August 06, 2007 - 10:28:24 AM »
Hmmm... The secret...
No secret, just hard work. I made some tools from bent nails to get under the edges. I also made a tool that fits the contour and used it to hammer out the big dents. I made it from a 3"-4" 3/8 bolt, I ground the head down to fit the bezels from behind. Once the dents were close, I sanded them down smooth then polished them out.
Stanless will be a little harder to work, but should be about the same process. I will let you know when I get to doing the stainless stuff.
Dave :wave:
Dave
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #10 on: August 06, 2007 - 05:54:01 PM »
I was taught a different trick with polishing - I started with a standard Dual-Action sander outfitted with 400 grit sandpaper, then went up to 600, 800, 1000, 1200 and finally 1400 grit paper.  Then lastly used a bench grinder/buffer (the buffer part) for the final shine.  It took forever, but it looked like a mirror when I was done.
Offline purple1
« Reply #11 on: August 06, 2007 - 08:30:40 PM »
 :thumbsup: Thats almost what I did. I just skiped the 800-1400 grit, went from 600 to 1500 grit then polished on the wheel with buffing compound. Some very fine steel wool helped to remove the anodize coating also.
All done now, just need to wax after the paint cures. And I am not even using these on the purple car. One set will go back on the orange car of mine. One set are now extras. the botom bezels in the second pic are restored from Tuff Wheel Restorations that will go on the purple car, and man did they cost me...
Next... Grills...  :dunno:
Dave :wave:
Dave
