Author Topic: Biggest Headers  (Read 4492 times)
nivvy
Re: Biggest Headers
« Reply #15 on: August 10, 2007 - 09:29:07 AM »
http://www.ttiexhaust.com/Header-2%20Big%20Block/440-200.htm
Im getting those....exspensive but who cares... polished ceramic coated also..... :cooldancing:  :burnout:
do you really have to tilt the motor to get them in???
Offline 73440cuda
Re: Biggest Headers
« Reply #16 on: August 11, 2007 - 09:06:22 AM »
The passenger side went in without lifting the engine, you just have to get the car high enough in the air to put them in from under the car.  The drivers side was a bit more challenging, you will have to lift the engine about 2" to fit them in.  I did this myself with no help.  I'm sure it would be easier with another set of hands.  TTI P/N for 1 7/8": TTI440-178C4
nivvy
Re: Biggest Headers
« Reply #17 on: August 11, 2007 - 10:35:06 PM »
It says the 2" will fit with my eddy heads but man the hedmanns i have now almost touch the steering shaft....TTI must be a much better design...
Re: Biggest Headers
« Reply #18 on: August 12, 2007 - 02:23:01 PM »
TTi are a much better design , I use them all the time
nivvy
Re: Biggest Headers
« Reply #19 on: August 23, 2007 - 10:37:57 AM »
what steps did you do in lifting them??? thx
Offline 73440cuda
Re: Biggest Headers
« Reply #20 on: August 25, 2007 - 10:01:54 AM »
Drive the car on ramps, unbolt both motor mounts, use a floor jack with some wood to place under the oil pan and jack it up.  Remove the starter, and slide the headers in place from under he car, replace the starter and bolt up the header.  The higher you get teh car in the air the easier it wil be.
nivvy
Re: Biggest Headers
« Reply #21 on: August 25, 2007 - 10:52:14 AM »
can you remove/put in the starter with the TTI Headers already in??? with mt hedman's you have to slide the starter in the same time as the header a real pain in the but??? when you talk about putting the wood under the oil pan what part of the pan??? it wont crush??? or are you talkig like down the let side of the pan where the bols are to tilt it side ways...
« Last Edit: August 25, 2007 - 10:57:23 AM by StrOkEr »
Offline 71chmark
Re: Biggest Headers
« Reply #22 on: August 25, 2007 - 11:01:31 AM »
I just put a set of Thorelys from Summit on my 440.  1 3/4". They fit beautifully. They don't hang down. I didn't have to beat them and they were about 300$ cheaper than TTIs.
I may be schizophrenic,
nivvy
Re: Biggest Headers
« Reply #23 on: August 25, 2007 - 11:03:10 AM »
were they ceramic coated??? part# ??? were you running power steering??
DTE-152-C I see they fit power steering as well??? did you tilt motor to get in?? what heads you running??
« Last Edit: August 25, 2007 - 11:10:51 AM by StrOkEr »
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: Biggest Headers
« Reply #24 on: August 25, 2007 - 11:10:37 AM »
I dont think Chryco did much to those TTI they put on 4c's cuda.  I talked to him about the design when we were at Carlisle.  He said they fit with really no modification.  He said that they were designed to fit that tight under the car.  Maybe Im missing somthing, this is just what I remember from our conversation at the hotel.
Cuda Guy
Member Since January 14, 2002
nivvy
Re: Biggest Headers
« Reply #25 on: August 25, 2007 - 11:13:40 AM »
[/quote]
I have angled plugs also??? nice price.... I really want 2"'s headers...need every edge for Cuda Guy  :burnout:
nivvy
Re: Biggest Headers
« Reply #26 on: August 25, 2007 - 11:30:35 AM »
also how do you break in the headers???
  • Pearl Harbor, HI
    • C-C.com
Re: Biggest Headers
« Reply #27 on: August 25, 2007 - 12:49:32 PM »
Your going to need it!!!    :aarg:
Cuda Guy
Offline 73440cuda
Re: Biggest Headers
« Reply #28 on: August 26, 2007 - 05:14:01 PM »
Everyset of headers I've had I had to unbolt the headers to put in a starter.  It would be best if you used a small square of plywood or something similar under the lowest part of the pan.  It will not crush, because the weight of he engine will be spread out over the area of the wood.
