Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
VIN, Fender Tag and Broadcast Sheet Numbers
NEED HELP IDENTIFYING 426 HEMI BY THE NUMBERS
« previous
next »
Print
Pages: [
1
Author
Topic: NEED HELP IDENTIFYING 426 HEMI BY THE NUMBERS (Read 10330 times)
73HEMIRALLYEGUY
Jr. Member
Mean Green
on:
August 10, 2007 - 12:42:58 AM »
I have what I believe to be a 1969 426 hemi from a coronet or a charger. But there seems to be some conflicting info between the engine casting number and the engine block boss numers. Any and all help will be so greatly appreciated. The right side of the engine block casting number reads 2468330-1. The left side block casting number reads 2468330-1 with a date code 10-7-68. Now here's the kicker. The pad on the front of the engine block has only 4 symbols. Looking at the engine from the grill in the lower left corner is WT in large letters. In the center of the pad is an upside down 1 and in the 3 0'clock position of the pad is another 1 stamped sideways with the top of it pointing to the center of the pad. Now here is the real confusing part. On the lower right side of the block is the Numbers matching pad with these numbers 9A215434. Decode the first two digits and you get 1969 and the plant it was built in. The thing I don't get is the lack of info on the top pad. No cid no date. HELP!!!
Logged
RusTy/SE
Sr. Resident
Just havin' fun
Re: NEED HELP IDENTIFYING 426 HEMI BY THE NUMBERS
Reply #1 on:
August 10, 2007 - 06:35:29 AM »
According to 'Big-Block Mopar Performance' by Chuck Senatore on pages 4-5, 2468330 is the casting number for 64-71 426; WT indicates water test. Anyone else have any ideas about the lack of a date stamp on the front pad?
Russ
Logged
Russ
2001 Durango 1B4HS
1970 Challenger JS29U
Restoration thread:
http://www.cuda-challenger.com/cc/index.php?topic=27173.0
Alaskan_TA
Guest
Reply #2 on:
August 10, 2007 - 10:35:27 PM »
With the Hemi and 440 engines, if the intake surface was ever milled some of the numbers could have been milled away?
The Lynch Road plant did not build Chargers in 1969 if that helps narrow your search down some.
Barry
Logged
73HEMIRALLYEGUY
Jr. Member
Mean Green
Reply #3 on:
August 11, 2007 - 10:07:29 AM »
Thank you very much for the info. Does anyone know a Hemi Guru or a Hemi web site to contact about more information and history on this matter.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
