Author Topic: No spark  (Read 656 times)
Offline cmesa
No spark
« on: August 10, 2007 - 02:19:25 PM »
I have an electronic ign. sytem. My problem is I have no spark getting to plugs. Can this be a bad ign. box?
Offline ntstlgl1970
  • T a c o c a t
Re: No spark
« Reply #1 on: August 10, 2007 - 02:55:14 PM »
Which ignition do you have? The chrysler one or MSD etc??
If chrysler:
1. unplug the coil wire from the distributor, set near a good ground (1/4" or so).
2. unplug the distributor 2 wire plug.
3. turn the ignition to the on position
3. using the harness end of the distributor plug, scratch the exposed terminal to a good ground, you should see a spark from the coil wire to ground.
Let us know what happens
Re: No spark
« Reply #2 on: August 10, 2007 - 06:51:05 PM »
How do you know there is no spark? What testing have you done? Have you recently made any changes to the engine bay? If you are familiar with a volt meter, with the key in the "on" position, you should have around 9-10 volts on the "+" side of the coil. If you have that, we can move on from there. It could be ignition box, coil, ballast resistor, bad wiring, bad ignition switch...
