Author Topic: Moog Front End Kit Part Numbers  (Read 77805 times)
Offline mmccarty
  • My other ride...
« on: August 12, 2007 - 03:25:28 PM »
Here are the part numbers I came up with for an order with Rock Auto for everyones reference.
This "kit" includes idler and pitman arms, the UCA cam adjusters, and bumpers for $408.
ITEM        PRICE_CORE_QTY_ EXT PRICE
MOOG K7041   Idler Arm                                           $ 35.79 $ 0.00 1 $ 35.79
MOOG K7076   Pitman Arm                                        $ 51.79 $ 0.00 1 $ 51.79
MOOG ES319S Tie Rod End Adjusting Sleeve  (9/16")     $ 13.77 $ 0.00 2 $ 27.54
MOOG K783     Ball Joint                                           $ 38.79 $ 0.00 1 $ 38.79
MOOG K772     Ball Joint                                           $ 21.79 $ 0.00 2 $ 43.58
MOOG K5255   Stabilizer Bar Link                                $ 5.64 $ 0.00 2 $ 11.28
MOOG K408     Control Arm Bushing Kit                        $ 23.99 $ 0.00 1 $ 23.99
MOOG ES401L  Tie Rod End (9/16")                            $ 15.40 $ 0.00 2 $ 30.80
MOOG K791     Control Arm Bushing                            $ 10.56 $ 0.00 2 $ 21.12
MOOG K781     Ball Joint                                           $ 38.79 $ 0.00 1 $ 38.79
MOOG K7016A Strut Rod Bushing Kit                            $ 12.98 $ 0.00 1 $ 12.98
MOOG K5241   Stabilizer Bar Bushing Kit                       $ 5.79 $ 0.00 1 $ 5.79
MOOG ES401R Tie Rod End  (9/16")                             $ 15.40 $ 0.00 2 $ 30.80
MOOG K8243A Cam Bolt Kit                                        $ 13.75 $ 0.00 1 $ 13.75
MOOG K3180 Control Arm Bumper                                $ 5.94 $ 0.00 2 $ 11.88
MOOG K7293 Control Arm Bumper                                 $ 4.70 $ 0.00 2 $ 9.40
Offline alphabuck
    • Pics of my project
Re: Moog Front End Kit Part Numbers
« Reply #1 on: December 20, 2007 - 06:17:17 PM »
will do this package to anyone on this board for slightly less than what i would get to my local shops.  389.00 complete.  can also offer a house brand version of the same kit that would have a moog idler and strut rod bushings and cam bolt kit. the rest of the stuff would be standard stuff for 275.00 complete for all.
Offline EVIL72
« Reply #2 on: January 05, 2008 - 03:36:17 PM »
 Good luck with the idler arm, I'd check that one first. I went through a few of them on a 72 Demon and all of them were made too big to fit, maybe a bad batch  :dunno:
  I finally tried one made by Spicer and it fit perfectly.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline autoxcuda
    • Spring Fling
« Reply #3 on: November 21, 2008 - 11:10:30 PM »
My moog one fit my 73-76 A-body K-member with large sector pitman setup.
Did the spicer one have a metal to metal bearings instead of uranthane bushings??
I think this was a TRW idler on top with that cruddy plastic bushings  :puke: The moog is on the bottom.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline dougs bs23
« Reply #4 on: March 04, 2009 - 05:25:54 PM »
what would the part numbers be for the 11/16 tie rods and sleeves? :clueless: :dunno:
Offline RT Dude
« Reply #5 on: March 15, 2009 - 07:39:30 PM »
 :clueless: Would this be the correct set for my 70 - 440 R/T Challenger  :dunno:
« Last Edit: March 15, 2009 - 07:47:36 PM by RT Dude »
Brent
« Reply #6 on: March 18, 2009 - 11:03:51 PM »
Part#s for the 11/16 tie rod parts are
ES440S -tie rod sleeve
ES355RL -left tie rod end
ES352R - right tie rod end
« Reply #7 on: March 18, 2009 - 11:06:38 PM »
YEs for the most part it is correct ,the Pitman arm & Idler arm changed between 71-73 & it doesn`t specify what year this part list is for so be careful with those 2 parts , early the pitman & idler pointed down later both went below the center link & pointed up through the center link
Offline tommyg29
« Reply #8 on: June 18, 2009 - 09:27:58 AM »
This is what I am told is a moog part fitting my late (6-71) 71 cuda.
Offline Gmoff22
« Reply #9 on: July 06, 2009 - 07:17:56 PM »
Just ran through most of these parts plus some more at Autozone with Duralast parts for a little over $400...should I return and reattack for Moog (not familiar with them)?
Thanks
G-
USAF Pilot
'72 Challenger Rallye - http://s595.photobucket.com/albums/tt36/gmoff22/Challenger/
'05 Ram SRT-10 Quad Cab - http://s595.photobucket.com/albums/tt36/gmoff22/SRT-10/
'05 Magnum R/T AWD
« Reply #10 on: July 18, 2009 - 01:38:14 AM »
I would , the Moogs parts don`t run a lot more $$
Offline Chlngrcrzy
« Reply #11 on: July 18, 2009 - 08:57:36 PM »
I have been gathering up a few parts through Rock Auto. Awesome people to work with and prices are very reasonable.
Offline Gmoff22
« Reply #12 on: August 04, 2009 - 07:02:53 PM »
 :1zhelp:Now should I go Moog or Poly?  Does Moog make poly bushings?  From what I can tell they make some poly and the rest are OE rubber.  There is the Energy Suspension poly full kit for the Challenger which is what I have been considering getting.  The price difference is small and I've had a few folks tell me to go ploy.  Any thoughts from the gallery?
Thanks,
Eric
G-
USAF Pilot
'05 Magnum R/T AWD
« Reply #13 on: August 06, 2009 - 06:41:57 PM »
I use Poly bushings in most builds I do
Offline rebelcuda73
« Reply #14 on: August 24, 2009 - 08:53:55 PM »
I am getting ready to rebuild the front end on my 74 cuda and was planning on using poly on most of the parts except for the upper control arms.I heard that moog makes a offset one that helps give you better camber!! Anyone use these and do they make them in poly??
