Author Topic: Moog Front End Kit Part Numbers  (Read 77806 times)
Offline Katfish
  • 70 Challenger
Re: Moog Front End Kit Part Numbers
« Reply #30 on: November 24, 2010 - 03:09:37 PM »
Here's the info for the offset bushings
« Reply #31 on: January 12, 2011 - 03:13:09 PM »
Part#s for the 11/16 tie rod parts are
ES440S -tie rod sleeve
ES355RL -left tie rod end
ES352R - right tie rod end
Thanks Neil! Parts ordered! Might as well have everything new... :grinyes:
Offline challengermaniac
« Reply #32 on: February 12, 2011 - 09:58:00 PM »
Any chance one of you frontend specialists can list the Moog frontend parts for a 70 Challenger TA?  The original Pitman arm says FAST RATIO followed by the Part Number and I assume the Moog Pitman arm will measure the same, but may not reference FAST RATIO with the original part number----- so, can I rebuild the original Pitman as opposed to replacing it and if so, where do I get those parts?
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
« Reply #33 on: February 12, 2011 - 10:44:52 PM »
That pitman arm is unique to T/A's and AAR's Firm feel has them. They are the only ones I know that makes them.
http://www.firmfeel.com/fastrati.htm
« Reply #34 on: March 05, 2011 - 11:34:58 PM »
Here are the part numbers I came up with for an order with Rock Auto for everyones reference.
This "kit" includes idler and pitman arms, the UCA cam adjusters, and bumpers for $408.
ITEM        PRICE_CORE_QTY_ EXT PRICE
MOOG K7041   Idler Arm                                           $ 35.79 $ 0.00 1 $ 35.79
MOOG K7076   Pitman Arm                                        $ 51.79 $ 0.00 1 $ 51.79
MOOG ES319S Tie Rod End Adjusting Sleeve  (9/16")     $ 13.77 $ 0.00 2 $ 27.54
MOOG K783     Ball Joint                                           $ 38.79 $ 0.00 1 $ 38.79
MOOG K772     Ball Joint                                           $ 21.79 $ 0.00 2 $ 43.58
MOOG K5255   Stabilizer Bar Link                                $ 5.64 $ 0.00 2 $ 11.28
MOOG K408     Control Arm Bushing Kit                        $ 23.99 $ 0.00 1 $ 23.99
MOOG ES401L  Tie Rod End (9/16")                            $ 15.40 $ 0.00 2 $ 30.80
MOOG K791     Control Arm Bushing                            $ 10.56 $ 0.00 2 $ 21.12
MOOG K781     Ball Joint                                           $ 38.79 $ 0.00 1 $ 38.79
MOOG K7016A Strut Rod Bushing Kit                            $ 12.98 $ 0.00 1 $ 12.98
MOOG K5241   Stabilizer Bar Bushing Kit                       $ 5.79 $ 0.00 1 $ 5.79
MOOG ES401R Tie Rod End  (9/16")                             $ 15.40 $ 0.00 2 $ 30.80
MOOG K8243A Cam Bolt Kit                                        $ 13.75 $ 0.00 1 $ 13.75
MOOG K3180 Control Arm Bumper                                $ 5.94 $ 0.00 2 $ 11.88
MOOG K7293 Control Arm Bumper                                 $ 4.70 $ 0.00 2 $ 9.40
Just wanted to confirm these are the Moog part numbers I am going to need for my 70 TA and if part k5241 is the Stablizer Bar Bushing Kit for the Front, what is the Part number for the Rear Stablizer Bar Bushing Kit?
Charlie
Edmonds, WA
Offline aris_unlimited
  • Project in full swing
« Reply #35 on: March 25, 2011 - 05:36:00 PM »
Showing my ignorance here, why would someone need a control arm bushing kit, and control arm bushings?
Cuda is gone :(
74 satellite, daily driver/project now
« Reply #36 on: March 25, 2011 - 06:44:47 PM »
Item listed as K408     Control Arm Bushing Kit are a pair of bushings needed for the UCA
K791     Control Arm Bushing is the single bushing for the LCA
« Reply #37 on: March 25, 2011 - 07:45:50 PM »
ahh ok. See, learn something new every day lol.
Cuda is gone :(
Offline Strawdawg
    • Vortex Buicks
« Reply #38 on: April 05, 2011 - 11:48:34 PM »
double check the steering arm (pitman arm) number as the later cars had a larger shaft...at least on the power steering boxes as I recall.
Remember that you need two each of the tie rod ends.  The outer ends are right hand threads and the inners are left hand threads....that is what the right and left in some of the comments mean....
« Last Edit: April 09, 2011 - 04:06:56 PM by Strawdawg »
Offline Ford.P51
« Reply #39 on: June 09, 2011 - 12:37:41 PM »
Just order some of these from Rockauto.com, thought I would update those prices:
Part Number   Part Type                              Price     Number   Total
MOOGK5255   Stabilizer Bar Link                  $ 4.17       2        $ 8.34
MOOGK5241   Stabilizer Bar Bushing            $ 5.79        1       $ 5.79
MOOGK781     Ball Joint                               $ 40.79      1       $ 40.79
MOOGES319S Tie Rod End Adjusting Sleeve  $ 13.95      2       $ 27.90
MOOGES401R Tie Rod End                           $ 12.93      2       $ 25.86
MOOGK7016A Strut Rod Bushing                  $ 13.88      1       $ 13.88
MOOGK783     Ball Joint                               $ 40.79      1       $ 40.79
MOOGK772     Ball Joint                               $ 16.55      2       $ 33.10
MOOGES401L Tie Rod End                            $ 13.38      2      $ 26.76
1969 Ford Mustang Mach1
1972 Challenger
Offline Road_Runner
« Reply #40 on: September 03, 2011 - 08:17:07 PM »
Anybody know the moog part numbers for the rear end: 3/4" sway bar bushings, leaf spring eye & shackle bushings & end links?  I've looked and I can't find any listings for these anywhere I've looked.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #41 on: September 03, 2011 - 10:54:08 PM »
Energy makes them in Poly , I would definatly use the poly sway bar link kit
 Mopar still has the shackle bushings
Offline Road_Runner
« Reply #42 on: September 15, 2011 - 10:36:46 PM »
Cool, thanks.
Offline Nu2Mopar
  • Nu2Mopar
« Reply #43 on: September 25, 2011 - 04:04:11 PM »
Do you know if the front sway bar link is the same one used on the 72 Cuda' rear sway bar link?
Offline Katfish
  • 70 Challenger
« Reply #44 on: September 30, 2011 - 10:53:14 AM »
Rear sway bar links for E-bodys are the same as the front links on 69 B-body.
Moog  K8266
