Moog Front End Kit Part Numbers
Author Topic: Moog Front End Kit Part Numbers  (Read 78052 times)
Re: Moog Front End Kit Part Numbers
« Reply #75 on: August 24, 2014 - 01:59:50 AM »
Ok guy I need your help I ordered all moog parts but my pitman arm part # 7076 but it is to big for my steering box shaft steering box is a new flaming river any help please  :clueless:
That's the part # for the large sector shaft steering box 73-74, you must have the smaller one .
Offline ec_co
« Reply #76 on: December 11, 2014 - 08:11:13 PM »
PMs replied.
SPECIAL DEAL:
I have one new kit red calipers 6 piston front, 4 piston rear. PM me for a special deal on this kit ONLY.
PMs replied?, but you only have 1 post count total?!? and this thread is about MOOG, not brakes ........ i'm confused .......
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline CUDA JAS
  • vroooooom!
« Reply #77 on: December 12, 2014 - 08:45:44 AM »
oh good...I thought it was just me.   :dunno:
74 'cuda 360/727
Just call me a gearhead!
Offline carcrazyguy
« Reply #78 on: January 14, 2015 - 03:57:05 PM »
So if I am reading this list correct.   These are the parts needed for a complete 70-74 E-body front rebuild.  :dunno:
MOOG K7041   Idler Arm
MOOG K7076   Pitman Arm
MOOG K783     Ball Joint
MOOG K772     Ball Joint
MOOG K5255   Stabilizer Bar Link
MOOG K408     Control Arm Bushing Kit
MOOG K791     Control Arm Bushing
MOOG K781     Ball Joint
MOOG K7016A Strut Rod Bushing Kit
MOOG K5241   Stabilizer Bar Bushing Kit
MOOG K8243A Cam Bolt Kit
MOOG K3180 Control Arm Bumper
MOOG K7293 Control Arm Bumper
Part#s for the 11/16 tie rod parts are
ES440S -tie rod sleeve
ES355RL -left tie rod end
ES352R - right tie rod end
Any forum sponsors that sells these?
Offline anlauto
« Reply #79 on: January 14, 2015 - 03:59:50 PM »
I found the best prices at Summit Racing and Free shipping too !
Offline carcrazyguy
« Reply #80 on: February 06, 2015 - 01:25:06 PM »
So looking to order the front end kit.  I decided to check.. :ebay: just because.  It appears this kit has some of the parts listed above.  Yet other parts numbers are not matching up?
http://www.ebay.com/itm/New-Moog-Suspension-Front-End-Rebuild-Kit-336172-/291353768264?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3APlymouth&hash=item43d609b148&vxp=mtr
Front Upper Control Arm Bushings - K408
Front Lower Control Arm Bushings - K791
Upper Ball Joints - K772
Lower Right Ball Joint - K781
Lower Left Ball Joint - K783
Front Strut Rod Bushing Kit (Standard) - K7016A
Inner Tie Rod Ends - ES401L
Outer Tie Rod Ends -ES401R
Tie Rod Sleeves - ES319S
Front Sway Bar Bushings - K5241
Front Sway Bar Links (Heavy Duty) - K8989
Idler Arm - K7041
One-piece external forged housings.
Boots made from superior rubber compounds stand up to extreme temperatures and flex stress while providing a complete seal to keep out dirt and debris.
Rotational parts include a full ball stud and a complete 360 degrees of motion.
Powdered metal gusher bearings allow for maximum grease flow and lubrication.
Patented steel plate enclosures eliminate excess radial and axial movement of the ball stud.
« Last Edit: February 06, 2015 - 01:27:22 PM by carcrazyguy »
Offline carcrazyguy
« Reply #81 on: February 22, 2015 - 06:42:16 PM »
Okay.... :clueless:  so how does this kit from Mancini differ from the original list from RockAuto?  :dunno:
Mancini Racing Front End Rebuild Kit, Super
http://www.manciniracing.com/man19ebodsup.html
Fits: 1970-74 E Body
SUPER KIT: inner / outer tie rod ends, upper and lower ball joints, control arm bushings, stabilizer link kit, strut rod bushings, control arm bumpers and adjusting sleeve.
EDIT...
Trying to find somewhere that I can order everything that should be replaced on the front suspension during a rebuild.  I don't see an idler arm , cam bolt kit or pitman arm listed?   :dunno:
« Last Edit: February 22, 2015 - 06:47:09 PM by carcrazyguy »
Offline carcrazyguy
« Reply #82 on: February 22, 2015 - 06:52:47 PM »
Got an email from another member about this kit from Spicer.
http://www.billrolikenterprises.com/proddetail.asp?prod=204
Home » 2 SUSPENSION-FRONT
 Front Suspension Rebuild Pkg.
Now available from Bill Rolik Enterprises is the PREMIER front suspension rebuild package on the market today. The Spicer Professional "Blue" Series is designed for those who want to do the job ONCE, and enjoy outstanding suspension and steering component service life in their vehicle. Package includes upper ball joints, lower ball joints, heavy duty inner and outer tie rod ends (11/16" diameter), heavy duty tie rod sleeves (11/16" diameter), upper control arm bushings AND adjuster cams, lower control arm bushings, lower control arm bumpers, upper control arm bumpers and strut rod bushings. FITS 66-72 B-BODY AND 70-74 E-BODY. ALL BOOTS ARE NOW SUPPLIED IN BLACK ONLY! #204
Offline cuda lover
« Reply #83 on: February 22, 2015 - 11:47:43 PM »
There is an $80 difference in price, and neither says what the brand of the parts are, or if the bushings are neopreme, rubber,etc
CUDA Lover
Offline 4406v
« Reply #84 on: February 23, 2015 - 09:57:25 AM »
I just bought all new Moog suspension parts for my 71 Cuda along with the fast ratio idler arm/pitman arm kit from Summit. They had it all in stock and the shipping was free. Their prices were better than any local auto parts store.
Here's the list I ordered by quantity part # and price each
2-K7293 upper control arm bumper $3.97
2-K5241 front sway bar bushings $4.97
4-K5255 front sway bar link kit $3.97 (I have a rear sway bar if the whole link won't work I'm going to use the bushings to rebuild the link)
1-K781 pass lower ball joint $35.97
1-K783 drivers lower ball joint $35.97
2-K772 upper ball joint l&r $14.97
2-ES401L inner tie rod $11.97
2-ES319-S tie rod adj sleeve $11.97
2-ES401-R outer tie rod $11.97
1-K7026 front strut rod kit $35.97
2-K7030 upper control arm bushing & eccentric bolt kit $26.97
POF-116-10026 fast ratio idler arm/pitman arm kit $179.46
Total $477.33
« Last Edit: February 23, 2015 - 02:27:27 PM by 4406v »
"Live for today, Tomorrow never comes"
Offline cuda lover
« Reply #85 on: February 23, 2015 - 11:27:56 AM »
can you post a list of the parts you ordered? That way each person does not have to reinvent the wheel (so to speak).
CUDA Lover
Offline Katfish
  • 70 Challenger
« Reply #86 on: February 23, 2015 - 05:33:09 PM »
I would get the offset UCA bushings
Offline carcrazyguy
« Reply #87 on: February 24, 2015 - 12:03:44 PM »
I tried to order the Spicer kit from BRE.   Bill stated that Spicer has sold/changed to Raybestos and kits are not available at this time.  I had to get parts so I ended up ordering from Mancini.
MOG-K7103 - Offset control arm bushings
MREKIT-1ES - Mancini Racing Front End Rebuild Kit (Moog Super Kit)
Includes..
MOG-ES401R - RH tie rod end (x2)
MOG-ES401L - LH tie rod end (x2)
MOG-ES319S - tie rod sleeve (x2)
MOG-K772  -  ball joint (x2)
MOG-K8243A - control arm cam bolt (x2)
MOG-K408  - control arm bushing
MOG-7293 - bump stops (x2)
MOG-K3180 - bump stop single (x2)
MOG-K791 - front lower control arm bushing (x2)
MOG-K781 - RH ball joint
MOG-K783 - LH ball joint
MOG-K7016A  - strut rod bushing kit
MOG-K5255  -  sway bar end link set (x2)
I thought about ordering from RockAuto but felt like I need to support a business that supports the Mopar brand.
« Last Edit: February 24, 2015 - 07:34:19 PM by carcrazyguy »
Offline JKcuda
« Reply #88 on: May 31, 2015 - 10:44:34 PM »
Anyone have additional info on a Moog pitman arm for a 72 cuda with the smaller shaft?  I'm going Moog everything else but can't seem to find one?
« Reply #89 on: May 31, 2015 - 11:32:34 PM »
The one from Rick I bought from before.
See details...Fits Barracuda 72' and up.
http://www.ebay.com/itm/MOPAR-Pitman-Arm-Savoy-Belvedere-Road-Runner-GTX-330-Polara-Coronet-R-T-/221781345126?hash=item33a332c366&vxp=mtr#ht_1147wt_662
