Author Topic: Gas tank sending unit wire  (Read 1352 times)
Offline dawgs 73
« on: August 12, 2007 - 04:14:48 PM »
Can anyone post a picture of where the fuel tank sending unit wire runs through the trunk? I had to have a new trunk put in and there is no hole to run it through where I would expect it to be. I have no problem drilling something, but I need an idea as to where it won't look outrageously out of place. Oh yeah, a '73 Cuda is what I am dealing with.
On a side note, it is 103 degrees out and I just hung a new gas tank. I have no idea as to what possessed me to do this today, except for my desire to finally get this bloody thing running and out of the garage at least once before the driving season is over.
Thanks in advance....
Re: Gas tank sending unit wire
« Reply #1 on: August 12, 2007 - 04:29:07 PM »
If you want to try drilling from down below, you can see the rubber grommet on the bottom of my trunk for the blue wire.
Offline dawgs 73
« Reply #2 on: August 12, 2007 - 05:00:02 PM »
That is exactly what I needed to see. Thanks Mike.............................
Offline 6packCuda
  • Eagle, NE... Member since 11/17/06
« Reply #3 on: August 12, 2007 - 05:32:59 PM »
Sorry to butt in here, but what is the little metal strap going from the nipple on the tank to the metal fuel line. Is it necessary because I didn't put mine back on. I still have it though.
Dave
« Reply #4 on: August 12, 2007 - 06:14:56 PM »
I believe its for static electricity ground strap. Any rubbing between tank, straps, and floor could create static.
Put it back on.
« Last Edit: August 12, 2007 - 06:16:28 PM by Topcat »
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: August 12, 2007 - 06:24:33 PM »
It might also allow your gas gauge to work.
Tom :2thumbs:
Tom
« Reply #6 on: August 12, 2007 - 06:37:18 PM »
Well, without this ground strap, your fuel tank sending unit won't be grounded, thus leaving your fuel gauge useless.
Offline 6packCuda
« Reply #7 on: August 12, 2007 - 07:02:35 PM »
Well that's odd. My fuel gauge still works the same as it always did.
Dave
« Reply #8 on: August 12, 2007 - 07:17:25 PM »
SOMETHING must be grounding that pickup tube.  :screwy: Do you have stock gauges, or after-market?
Offline 6packCuda
« Reply #9 on: August 12, 2007 - 08:02:46 PM »
Stock gauges. The fuel gauge has always been off a little. When the tank is full, the gauge reads 3/4. The strap was on it but when I installed my electric fuel pump I couldn't put it back on because I have about 4 or 5 inches of rubber hose between the tank and the pump. Maybe I'll just put a piece of wire from the nipple on the tank to a ground.
Dave
