TTI headers and your suspension
Author Topic: TTI headers and your suspension  (Read 3405 times)
Offline 4Cruizn
  • HEMI FISH
« on: August 12, 2007 - 10:13:36 PM »
Looks like I'm having some issues with clearance in the convertible.  After the recent trip to the NATS last weekend, I knew I had a problem.  I will get better pics tomorrow when it gets light but these should give you an idea.
Anyone else have this issue with TTI headers on their 440??
« Last Edit: August 13, 2007 - 11:05:02 AM by 4Cruizn »
Re: TTI headers and your suspension
« Reply #1 on: August 12, 2007 - 10:22:41 PM »
You are the only person I have seen have this issue , possibly bad mounts
« Reply #2 on: August 13, 2007 - 11:58:43 AM »
Ouch!!  :scared:
Offline cudasteve72
« Reply #3 on: August 13, 2007 - 12:26:34 PM »
I thought TTI's were suposed to be the best.  We've had no problems at all with ours on the 340.
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #4 on: August 13, 2007 - 02:50:12 PM »
That looks like the passenger side.  :dunno:  Could your idler arm be bent?  :clueless:
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: August 14, 2007 - 04:33:27 PM »
So I took the car to a local friend who does suspensions and things for some 20+ years and we came to the conclusion that it is not anything to do with the car,  the header just doesn't fit and hits the top of the idler arm . . . alot!  The only solution that we could come up with is to get a different header that fits properly.   :banghead:
Sometimes the problems just never end.   :crying:
« Last Edit: August 14, 2007 - 04:35:12 PM by 4Cruizn »
« Reply #6 on: August 14, 2007 - 04:38:28 PM »
Dave,
  Are your front suspension parts stock, or did you go aftermarket there? I'm just curious why you are the lucky one here.  :poopoke: For what TTI's cost, they sure should fit like a glove.
Offline EvilTwinATX
« Reply #7 on: August 14, 2007 - 07:11:16 PM »
I AGREE...That why I am wondering if there is a cheaper alternative...
if they didnt fit I could just cut 'em and modify them with a little two inch tubing... much simpler than creating from scratch.
Offline 4Cruizn
  • HEMI FISH
« Reply #8 on: August 15, 2007 - 12:44:25 AM »
At this point I'm not sure where I'm headed with this . . . I'm going to talk to my exhaust guy that did my 3" on the hardtop.  Maybe he can do something to help.
Maybe TTI has run into this before??
« Reply #9 on: August 15, 2007 - 03:14:06 AM »
I would contact Alena or Sam @ TTi send pix & see if they are willing to help you
Offline matt63
« Reply #10 on: August 19, 2007 - 10:14:19 PM »
Schumacher makes (or did anyway) very nice engine mount shims for their sandwich type engine mounts. http://engine-swaps.com/
Matt in Edmonton
'68 Valiant
Offline moper
« Reply #11 on: August 20, 2007 - 11:46:09 AM »
Make sure the rubber in the mount hasnt squished under the weight of the engine over time. Also, try loosening both mounts (the cross bolt on each side) and move the engine so it's centered between the mount pads on the K frame. You can ususally "float" things around a bit. If the drver's side was on first, the pass side may have fallen deeper into the "V". Also, if your idler arm or pitman arm have any up and down travel, replace it. It looks like it might, and it's not supposed to.
Offline 4Cruizn
  • HEMI FISH
« Reply #12 on: August 20, 2007 - 01:51:26 PM »
Thanks for the advice.  The motor mounts are new and look to be in good shape still as is the front end.  I had everything checked out at my local shop for problems before I posted for help.  Definitely a problem that I need to tackle.   :walkaway:
« Reply #13 on: August 20, 2007 - 01:53:46 PM »
In the chassis book it speaks of potential header tube interference in this area. The solution is to remove the idler, die grind the hole in the bracket until it is oblong. Check fit the idler until you have sufficient clearance. Once you have position you like, you weld a washer on to the idler mount to fix the new position. Then shim the steering box so your center link is equally positioned vertically as the new location of the idler.
nivvy
« Reply #14 on: August 20, 2007 - 09:06:36 PM »
Sounds like a headache to me...TTI says the headers I am getting will not work with aftermarket fast ratio pitman and something about aftermarket idler arm as well..... but I would definatley call TTI on this one.....
• Will not clear the quick-ratio extended length pitman arm and the idler arm
« Last Edit: August 20, 2007 - 09:11:21 PM by StrOkEr »
