Looking to trade 72 499 Stroker for 71 Challenger!!!
Author Topic: Looking to trade 72 499 Stroker for 71 Challenger!!!  (Read 5328 times)
nivvy
« on: August 14, 2007 - 12:58:49 AM »
Looking to get a super clean 71 Challenger!!! 440 or 440+Stroker only...
Why 71... was the year I was born...
72 Specs-- All Parts are New and the Custom Bigs Dominator/Heads only has 20 miles on it.....View the list carefully.... Thousands spent!! and have receipts...
650+HP Dont Run Hot and Pump Gas..... less than 500 miles since restored.... Autometer speedometer has exact mileage of car since restored...
Restoration Parts
Painted Curious Yellow
Challenger
T/A 6 pack Hood (up22)
71 Fender scoops
Gas Tank
Fuel Sending Unit
Flip Top Gas cap and Ring
Stainless Steel Gas Tank Straps
Filler Neck Grommet
Custom 500 Hood Emblems
Challenger Fender Emblems
Turn Signal Lenses
Window Cranks
Year One Challenger Floor Mats
Door Lock Levers
Arm Rest Pads
Trunk Bumpers
Parking Lenses
Gas Tank Pad
Rear Seat Divider Panel
Carpet (Year One)
Console Lock
Console Lid
High Beam Foot Switch w/ custom hippie dimmer foot pedal
Sunvisor Tips
Wood Grain Console Inserts (Year One)
Wood Grain Door Panel Inserts (Year One)
Headliner (Year One)
Hedliner Insulation (Year One)
Front Floor Pans Left & Right 3/4 Length
Rear Floor Pans Left & Right
Scat Sportsman Front Seats & stock rear w/ Custom upholstry
Stock Rear Seat w/Custom Upholstry
Pyle 6X9 & 5 1/4 Speakers
Panasonic Cd Player
Fuel Delivery
Edelbrock TM7 (port matched & blended to 4500 ot 4150 adapter)
Holley 1050 Dominator "BIGS"
Jegs Spring Return Kit
Aeromotive Fuel Pressure Regulator
K&N Valve Cover Breather
K&N Dominator 16" Air Cleaner
Edelbrock 4150-4500 2" Adapter(15 HP pickup)
Summit Fuel Filters
Summit Fuel Filters
Valvetrain
440 Source 1.7 Full Neddle Bearing Roller Rockers / shims etc..
Mopar Perfomance Hold downs
Earls Breather/PCV
440 Source Fabricated Aluminum
Edelbrock Intake Bolt Kit
Summit Fuel Delivery Kit
Billet Fuel Pump
Fram Fuel Filter/Housing
Aeroquip Stainless Steel Hose (-6 20Foot)
Aeroquip Aluminum Fittings  (several)
Shim Package
Bronze shank for roller cam/distributor
Gauges (Autometer PHANTOM)
Trans Temp Sender
Speedometer sender
Trans Gauge 2 1/16
Fuel Pressure Gauge 2 1/16
Clock 2 1/16
Fuel Level 2 5/8
Oil Pressure 2 5/8
Water Temp. 2 5/8
5" Speedometer
Voltmeter 2 5/8
5" Monster Tach
Performance
Mancini Aluminum Water pump & housing (high flow)
Mancini HV Water Pump
Mancini B/RB Aluminum housing
Mopar Voltage Regulator
MSD 6 AL
MSD Pro Billet Distributor
Pro Form High Torque/Light Starter
Comp Cams XR286R/ Lifters (Roller) 286/292 dur @.50 248/254---.576/.582 lift w/ 1.7 rockers .620/.627 lift
Custom Mancini Racing Chromoly Pushrods
Cam Bearings (Federal Mogul)
Flowmaster Super 40 Mufflers (3 inch) (2)
Bee Cool Radiator Kit (700hp)
Pete Jackson Gear Drive (noisy)
March Serpentine Pulley set w/ power steering pulley
Miloden Oil System
Felpro Headgaskets (1009)
Ray Barton Mopar Performance Stroker Kit 4.150 (4340)
JE Pistons (Flat top) 6.76 rod / .990 pin / 1.865 comp. Hght.
Manley rods (RBRE) 4340 H Beam 6.76 / .990 pin
Clevite Bearings
Federal Mogul Main Bearings
Akerly & Childs file fit moly rings
Mopar engine kit
Ati Super Damp w / steel hub
Balancing / pin fit / rods
**Chenowith Racing Main Stud Girdle Kit**
Stroker Tray Mopar Perf. 4.150
High Volume Oil Pump
Moroso Solid Motor Mounts
3 Inch Exhaust With Flowmaster Super 40's
Hedman Headers (Elite)
Edelbrock Stage 3 Fully Ported Heads w/ K Motions Springs / 10* Locks / Titanium Retainers Hensley Ported 320 CFM (no tubes)
Victor Reinz Nitro Seal Header Gasket
Transmission
Coan stall (pro street/competition) 3200
Turbo Action Cheetah Forward Manual Valve Body
B&M Trans Cooler
TCI Aluminum Transmission Pan
Mancini Transmission Dipstick
MRE Rebuilt 3rd Member 742 Case 3.91 Ratio (Auburn Gear)
Mopar Performance 8 3/4 Adjustable Pinion Snubber
Mopar Performance Rebuild Kit (race)
Flexplate B&M (8 bolt)
5.0 Kickdown lever
US Car Tool Driveshaft Loop Bolts to crossmember
Spicer 7290 Solid U Joints(2)
CSR Carbon Fiber Scatter Shield
Suspension
Mopar Super Stock Spring Kit
Mopar Spring Relo Kit
Mopar HD Torsion Bars (.960)
Solid Spring Eye bushing
PST Super Kit Polygraphite
PST Front Sway Bar Polygraphite
PST Pitman Arm
PST Sway Bar Bushings
PST Transmission Polygraphite Bushing
Wheels and Tires / Axel
Centerline Convo Pro's-----15*6 (3 3/4 inch) backspace & 15*10 (5 inch) backspace
Mickey Thompson Sportsman Front
Mickey Thompson ET Streets 28*12.5*15 but car will fit 28*13.5*15's
Competition Engineering 3 Way Shocks 90/10 front
Competition Engineering 3 Way Shocks  50/50 rear
3" Wheel Studs
Rearend Gasket
Strange Axels
Green Axel Bearings
Brakes
New Rear Brake Pads/Wheel Cylinders
Stainless Steel Brake Co. Disc Brakes  (11 inch 4 Piston Slotted Rotors)
Misc.
Chrome Bolt Package
Mopar Performance Chrome timing cover
Powermaster Chrome Alternator
Autometer Triple gauge pod
Mopar Performance Engine Gasket Set
B&M Megashifter
Schumacher Torque Strap
Power Steering Pump
Power Steering gear box (Lares)
Lokar Throttle Cable
Turn signal lever
Turn signal harness
Back up light harness
Turn Signal Flasher
Door Pins & Bushings
Weld Tech Custom Stainless Engine Kit
( Valley Pan / Distributor Hold Down / Power Steering / Alternator / Water Neck)
B & M Line Lock
B & M T Handle w/button
Grant Steering Wheel
Steering Wheel Adapter
Water Pump / Timing Cover Bolt Kit
ARP Head Bolts
Carburetor Gaskets
Main cap Stud kit (ARP)
Fuel Block off plate
Valve Cover Gaskets
Engine Machine work etc…
Heads $3,000
> 1) Edelbrock RPM heads 84CC
> 2) Full race port performed by Hensley Performance in
>Knoxville Tenn.
> 3) 11/32 race valves, 2.14/1.81.
> 4) Kmotion K1000 springs
> 5) Titanium retainers and 10 degree valve locks.
> 6) Push rod holes inlarged.
> 7) Race 5 angle valve job.
> 8) New K-motion K 1000 spring installed height of
>1.970, coil bind 1.090. Seat pressure 200 lbs, max lift
>of .750 (performed by Michaels performance).
Block Specs.
Motor specs
440 block bored .55 over
.013 deck height (below deck)
1973 block
Piston to Valve Clearance
exhaust------------  .186
intake--------------   .130
Piston Volume -6
4.375 Bore
4.150 Stroke
.039 compressed gasket thickness
84 CC combustion chamber
4.410 Gasket Bore
Final Compression 10.92 to 1
.013 Deck Height (below deck)
The ONLY performance part not changed on the car is the MSD Blaster 2 coil...but works great!
Interested parties email picks to poolcircuit@atlanticbb.net and I will return pics as requested...
71  ONLY!
 :burnout:
« Last Edit: August 14, 2007 - 01:17:12 AM by StrOkEr »
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Looking to trade 72 499 Stroker for 71 Challenger!!!
« Reply #1 on: August 14, 2007 - 01:02:38 PM »
Good Luck, but I will be sad to see that great car leave.
« Reply #2 on: August 14, 2007 - 01:16:56 PM »
Actually stroker, you should keep your car.
1)  you were created in 1970
2) you were zero yrs old in 1971
3) you were 1 yrs old in 72
So 70 would be a recreation in progress and 72 would be a real life experience :stirpot:
Now for SIDS,   Should we shake you into sense?  you got a nice car-drive it-enjoy it :2cents: :burnout: :ylsuper: :bananasmi :cheers:
Offline moparclown
« Reply #3 on: August 14, 2007 - 01:39:38 PM »
I would clone that beauty if you wanted the look of a 71----you already have the quarter scoops and one sweet car.
nivvy
« Reply #4 on: August 14, 2007 - 03:19:12 PM »
Im only doing this 1 more time and it has to be a 71....  :burnout:
Offline 1BADFISH™
« Reply #5 on: August 14, 2007 - 03:23:15 PM »
Looking to sell or just trade?
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
nivvy
« Reply #6 on: August 14, 2007 - 08:10:00 PM »
Depends....??? I may sell then buy or mix it up...but am looking for a 71...
Offline MOPAR FANATIC
« Reply #7 on: August 24, 2007 - 10:57:19 AM »
 :faint: Say it isn't so,who's gonna keep on killimg all those ricer's after she's gone.  :nono: say you'll keep her.  :o
just love reading your kill stories.  :worshippy  :cheers: MO,FAN.Dave......................
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Offline 71bigblock
    • Steve's Mopars
« Reply #8 on: August 24, 2007 - 11:03:57 AM »
I've got a '71   :naughty:
Not for sale or trade.  Not now anyways.   :crazy:
Offline matt63
« Reply #9 on: August 24, 2007 - 02:49:34 PM »
If you have a similar plan for the '71 I'd strip your '72 down and build it back to stock or sell it as a roller.  You'll probably only get $0.10 or $0.20 on the dollar for what you've invested in the power train and other upgrades.  Just an idea. Advice is cheap and sometimes worth what you paid for it. :smilielol:
Matt in Edmonton
'68 Valiant
« Reply #10 on: August 24, 2007 - 04:50:50 PM »
True. Grill, tail panel, marker lights. The 73 is already a combination of mulitple years so combine the parts you want to get the look your after. I think it goes deeper than just appearance in this case. Consider this, half of the 71s out there were built in 70. Is that an issue?
Very good point.  Used performance parts don't command premium dollars whether dis-assembled or complete and this car is built to suit some pretty individual tastes. Score a 71 project as complete as possible and rebuild it with all the good stuff from the 73.  Put all the old used stuff on the 73 and sell it as a project with a good paint job. Body and paint are the two biggest obstacles to a large number of buyers. Replacing mechanical parts is easy by comparison and guys who are willing to tackle a complete driveline swap won't even try pulling the trigger on a spray gun.
nivvy
« Reply #11 on: August 24, 2007 - 05:40:52 PM »
that is silly low .10 to .20 cents??? not where im from....Ive already been offered a decent price way higher return than that..all parts are brand new...
no fake 71's here......like I said I was born in october 71 and want a 71 model....my 72 was made 1/16/72...
not looking for a 71 with equivalant HP...nice car with nice interior and suspension mods/rims.... I am going to building a different type of 440 motor....  :burnout:
« Last Edit: August 24, 2007 - 08:48:03 PM by StrOkEr »
Offline matt63
« Reply #12 on: August 24, 2007 - 11:19:58 PM »
If you find the right guy you might get more but I don't think you get a big premium for power train upgrades over a "restored to stock" car.  I know how much it costs to upgrade a power train.  All I am saying is that is that if a guy could find a stock motor, tranny and diff and paint it up nice and do a swap you might be further ahead than starting all over again - just something to think about.  I was thinking about doing this to my Cuda and selling the stroker separate but I doubt I would get enough for a used engine to make it worth my while.
Matt in Edmonton
'68 Valiant
nivvy
« Reply #13 on: August 24, 2007 - 11:58:55 PM »
I need a nice 71 challenger with a mild 440 engine in it....gonna pull motor and beef it up and put a F3 ProCharger on it  :burnout: dont tell CudaGuy...... :burnout:
As soon as I get a timeslip it wont last in my hands to long ??? as soon as I find the right deal on a 71 its gone!!! 1971 Challenger or Bust!!! I love the car to death but my heart is set on a 71..........  :cooldancing:
« Last Edit: August 25, 2007 - 04:01:47 PM by StrOkEr »
