Author Topic: Takin' out that Dodge logo from Chall door panel  (Read 798 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: August 14, 2007 - 10:03:54 PM »
Hey gang..
OK, I've ground down the heads of the logo studs, but apparently there's more to it than that... For those you have taken out the logo, was it drilling it out totally or will a little heat do it? I'm replacing the woodgrain on the door panel accent..
Thanks...
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Offline VTMopar
Re: Takin' out that Dodge logo from Chall door panel
« Reply #1 on: August 14, 2007 - 11:06:57 PM »
I just ground mine down and it came right out....   After I replaced the woodgrain, I put it back in, and used some liquid steel or glue (I forget) to "re-fasten" them.....
Vermont MOPAR
VT MOPAR
nivvy
« Reply #2 on: August 15, 2007 - 02:28:41 AM »
I ground mine down with a dremel and eventually they will pop right out...
Offline loco440
« Reply #3 on: August 15, 2007 - 09:31:15 AM »
Get a sharp nail,center it in the middle of the pin with two pieces of wood underneath either side of badge,and gently tap with small hammer on each pin (3)and it will drop out,to replace clean up pins and pop in and put araldite on to the pins,DONT glue the badge onto the new decal as the glue will melt it.
Offline MJS73
    • Mike's 1973 Challenger
« Reply #4 on: August 16, 2007 - 07:53:12 PM »
What I did was use the flat nose of a pair of pliers over the ends of the studs and twisted the pliers to round the studs, then the studs pushed right through.  To re-assemble, the new vinyl will hold them somewhat if you don't pre-pierce the vinyl, but a dab of silicone over the stud will hold it well.
www.mikes73.com
Offline 70challrtse
« Reply #5 on: August 20, 2007 - 09:37:18 PM »
Me too.
  • Charger Power!!
« Reply #6 on: August 20, 2007 - 09:45:42 PM »
Thanks guys.. I was able to finish the panels this weekend.. Turned out pretty good.. Just had to grind a little more with a spherical dremel grinding bit. That did the trick.. I was overly cautious.....
