Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
wiring question
« previous
next »
Print
Pages: [
1
Author
Topic: wiring question (Read 2346 times)
71chmark
Full Member
wiring question
on:
August 18, 2007 - 02:04:50 PM »
I bought a new engine harness from Year one for my 71 challenger electronic ignition. The old one just used the single ballast (looks like a couple of wires left hanging. Should I get a double ballast resister or does it not matter?
Logged
I may be schizophrenic,
Moparal
Permanent Resident
Re: wiring question
Reply #1 on:
August 18, 2007 - 08:42:56 PM »
I believe you need the dbl since the other 2 would supply 12v when cranking
Logged
71chmark
Full Member
Re: wiring question
Reply #2 on:
August 19, 2007 - 01:26:09 PM »
Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: wiring question
Reply #3 on:
August 19, 2007 - 02:06:49 PM »
as long as you use the 4 pin ECU the 2 pin ballast is fine
Logged
71chmark
Full Member
Re: wiring question
Reply #4 on:
August 19, 2007 - 04:16:12 PM »
Thanks. So I just need to figure out which wires to leave off.
Logged
67Vette427
Full Member
My other car is not a Rambler
Re: wiring question
Reply #5 on:
August 19, 2007 - 05:12:05 PM »
From what I remember I used a dual connector for the extra wire on the ignition side. I believe there was one wire you don't need. Check the instruction or Chryco will know.
Logged
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Chryco Psycho
Administrator
C-C.com Guru
Re: wiring question
Reply #6 on:
August 20, 2007 - 10:22:59 PM »
you will have dark blue twinned to two terminals on one end & brown & dark green on the other end , you do not use the dark green & either dark blue can be disconnected
Logged
JayBee
Resident
Re: wiring question
Reply #7 on:
August 20, 2007 - 11:49:07 PM »
Look in "The Rest of Tech" area for a thread called "wires from ignition box to where?" thread. There's a couple of diagrams for 5 pin ECU's if that's what you have.
Logged
John
1970 Barracuda convertible
2014 Toyota Avalon
67Vette427
Full Member
Re: wiring question
Reply #8 on:
August 21, 2007 - 01:49:58 AM »
that's good info. If you need it I think I have one out in the garage from my Challenger ignition.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
wiring question
