Author Topic: Fasten Seat Belt Light - HELP!  (Read 1240 times)
Offline VTMopar
« on: August 18, 2007 - 09:55:09 PM »
 My '74 Challenger lights and seat belts worked fine; all of a sudden, the "fasten seat belt light" on the right side of the dash continues to stay lit after seat belts are fastened.   It goes out when engine is off and either door is open -- but then comes back on (after a few seconds) when (either) door is closed (no key in ignition).   Anybody got any ideas as to what might have happened?   Was working perfectly before?
 :feedback:   Any help would be appreciated.
Thanks
Vermont MOPAR
VT MOPAR
Re: Fasten Seat Belt Light - HELP!
« Reply #1 on: August 18, 2007 - 09:59:03 PM »
Not sure, but did you reset the relay on the drivers fenderwell? Or try unplugging it at the relay?
Offline VTMopar
« Reply #2 on: August 19, 2007 - 10:40:36 PM »
Thanks for the tip -- tried it -- but no luck..... not sure what is going on.... just stays on virtually all the time.    This year was the first of the interlock system (weight ont he passenger seat = must have seat belt fastened or car won't start).... so suspect the wiring is a bit complicated.   Strange thing is -- all was fine for nearly a year -- then "wam" -- light stays on......   Perhaps someone out there is a wiring geru?
Vermont MOPAR
VT MOPAR
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #3 on: August 20, 2007 - 02:27:49 PM »
seat belt system only works with the ign. on.
 so if it is working with ign. off- I suspect that you have a short in the wiring- I would check around the bulkhead harness wiring and up around the dash area. look for melted wires or tape wrap.
try removing a fuse at a time to see what circuit turns it on.
if all fuses are out- then it's time to trace out the main power wires!!!
John Mac
Offline buzzard
  • Why is their AIR
« Reply #4 on: August 20, 2007 - 10:26:58 PM »
Check your cont. unit to see if it is pluged in all the way. a lose plug gives your seat belt module a mind of its own. Been there done that.
Offline VTMopar
« Reply #5 on: August 22, 2007 - 09:57:46 PM »
Not sure what you are referring to Buzzard.... can you  please elaborate some?
Thanks
Vermont MOPAR
VT MOPAR
Offline buzzard
  • Why is their AIR
« Reply #6 on: August 23, 2007 - 07:48:34 AM »
 In 74 they started using a seat belt cont. if you have one it is located under the dash left side behind and above heater cont. It has 2 multy conductor plugs going to it. The 2 large wires were prone to poor contact. Make odd things happen. Good luck. It's blue in colour, 5" X 3" x 1"
Offline VTMopar
« Reply #7 on: August 23, 2007 - 08:15:50 PM »
 Buzzard
:dupe:    OK... I feel totally stupid -- what is a "cont." ???   ??? ???
Vermont MOPAR
VT MOPAR
Offline 71 DEPUTY
    • Cardomain
« Reply #8 on: August 24, 2007 - 07:36:16 PM »
the seat belt control unit. It has a side card connector on it.
Offline VTMopar
« Reply #9 on: August 26, 2007 - 10:18:16 PM »
Thanks for the advice -- haven't had a chance to get out to check it out, but I'm guessing your pointing me in the right place  ;D
Vermont MOPAR
VT MOPAR
