70 Challenger Fendertag decoding
Author Topic: 70 Challenger Fendertag decoding  (Read 3593 times)
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« on: August 19, 2007 - 08:36:20 AM »
Was decoding a 70 Challenger fendertag on a projekt car that im about to buy, but my reedbok there is some coeds missing. So what does 26 and En2 on the first line, G35 on third line, 000, Co7, 090318 on fifth line say?
Thanks :cheers:
« Last Edit: August 19, 2007 - 08:39:05 AM by ESGEE »
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline ksierens
    • 70 Challenger Resurrection
Re: 70 Challenger Fendertag decoding
« Reply #1 on: August 19, 2007 - 08:44:58 AM »
26 is a 26" radiator,  EN2 is "End of sales code, assembly line 2", 000 is "Upper Door Frame: Full door panel",
", C07 is the scheduled build date "November 7th, 1969", and 090318 is the order number.  Sorry I don't have a G35 in my tag, so I don't know what it is.
Try this cool on-line decoder.  You may have to use Internet Explorer to run it though.
http://www.stockmopar.com/mopar-fender-tag-decoder.php
« Last Edit: August 19, 2007 - 09:41:20 AM by ksierens »
Kurt - SE Michigan
Offline ESGEE
    • SG´s site
« Reply #2 on: August 19, 2007 - 08:49:06 AM »
Thanks, i will check that out :cheers:
70 Charger 500
Offline Culvers
« Reply #3 on: August 19, 2007 - 10:32:08 AM »
G35 is a mirror code, but I think you mean G33 or G36. I never seen G35 on '70 Challengers.
C07 is December 7th, 1969
« Last Edit: August 19, 2007 - 10:37:55 AM by Culvers »
Offline ksierens
« Reply #4 on: August 19, 2007 - 10:48:19 AM »
Yeah, my bad.  Mine is B04, November 4th.  My also has the mirror codes G31 'Outside RH Manual Racing Mirror - Manual/Chrome' and G33 'Outside LH Remote Racing Mirror - Manual/Chrome'
Kurt - SE Michigan
Offline ksierens
« Reply #5 on: August 19, 2007 - 10:53:06 AM »
Looks like the G35 code is 'Roof Type OR Color:  Delete Standard Outside Mirror'
Kurt - SE Michigan
Alaskan_TA
« Reply #6 on: August 19, 2007 - 07:20:40 PM »
G35 is not a valid code for 1970 Challengers, can you check the tag again?
Offline bullet cuda
« Reply #7 on: August 19, 2007 - 08:35:00 PM »
Was just wondering whats code for stripe package on r/t.
Alaskan_TA
« Reply #8 on: August 19, 2007 - 10:03:54 PM »
It depends. Body side stripe? Bumble Bee stripe? Color? 1970 Challengers had a pretty long list of possible stripes, including pinstripes.
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #9 on: August 20, 2007 - 01:29:12 AM »
challenger stripe codes: 'V5*' is vinyl side moulding (* is color)
                                 'V6*' is longtitude R/T stripe
                                 'V7*' is pinstripe
                                 'V9*' is bumblebee stripe.
Offline ESGEE
    • SG´s site
« Reply #10 on: August 20, 2007 - 02:28:10 PM »
I have a real bad photo of the fendertag, but since it have G31 could the G35 be a G33 insted? The vintag is even worse photo off, but a good Dark burnt Orange SE project is worth the chanse :bigsmile:
70 Charger 500
Alaskan_TA
« Reply #11 on: August 20, 2007 - 10:13:02 PM »
That is G33.  :thumbsup:
Offline RusTy/SE
  • Just havin' fun
« Reply #12 on: August 20, 2007 - 11:06:13 PM »
My R/T SE tag has G31 and G33 - chrome mirrors in my case :thumbsup:
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline bullet cuda
« Reply #13 on: August 20, 2007 - 11:18:14 PM »
Thanks the code was V6.
Offline Rooster
  • 440 Magnum
« Reply #14 on: October 11, 2007 - 01:49:01 PM »
                                 'V7*' is pinstripe
I am sorry to hijack, but I used the tag generator stated within this thread and came up with:
"V68 - Delete Stripes"
Does that mean I my car had no stripes on it?
Also is the information I gathered from the tag generator the only info availible from this tag?
I know I am a novice, but it seems like there should be more to it.....my whole car is summed up in 100 words or less.
Thanks!
-R-
Its's not how fast you go....its how fast you get there!
