Author Topic: Wires from ignition box to where?  (Read 709 times)
Offline cmesa
« on: August 20, 2007 - 12:56:23 PM »
I would like some help in figuring this one from the iginition box (Plug) out there are about 5 or 6 wires, can anyone tell me where each one goes to, since I have a blue with a (yellow or dirty white strip) wire going nowhere. It has been cut. I read some wiring diagrams but they do not show the ignition box.
Thank You All
Offline JayBee
Re: Wires from ignition box to where?
« Reply #1 on: August 20, 2007 - 02:43:52 PM »
Hi. The pic isn't the best so I'll try to describe it too.
Top left wire: Green - Not Used
Top right wire: BLACK/YEL - negative side of coil
Right side wire: BLUE/YEL - IGN #1 (I spliced it to my ballast's blue wire)
Bottom right wire: GREY/BLK - distributor plug
Bottom left wire: BROWN/WHT - distributor plug
This was for a 1970 small block, not sure if others are different.
John
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #2 on: August 20, 2007 - 04:25:58 PM »
If you have a 4 prong ballast resistor, this is the diagram.
