Harmonic balancer question
Author Topic: Harmonic balancer question  (Read 672 times)
Offline burrpenick
« on: August 22, 2007 - 12:19:14 PM »
My 360's balancer has some of the rubber packing coming loose. Is there something I should be before I re-install this part? No, I can't afford a new one at this time, but I wondered if I should try to epoxy/glue the loose stuff.
GEORGE
currently Moparless
Offline Aussie Challenger
Re: Harmonic balancer question
« Reply #1 on: August 22, 2007 - 08:43:58 PM »
Don't fit the balancer, it is starting to deterioate, a new or rebuilt one is the only way to go. I have seen these come off usually with expensive results. It is much cheaper and easier now.  :bananasmi
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #2 on: August 22, 2007 - 09:22:51 PM »
yup
Offline Ross
« Reply #3 on: August 23, 2007 - 04:25:59 PM »
Buy a used one to save some cash right now, but don't try to cheap out that much and glue it on!! 10lbs of steel turning at 5000 rpms is a lot of momentum that could punch a nice dent in your hood, rad etc.
Mine shifted (cracked all the way around and rotated about 10°) on my 72 340 (externally balanced) and caused terrible vibrations.  God only knows what extra wear that did to the bearings.
'70 340 Challenger
A whole lot of rust and very little time to work on it...
