Author Topic: 499 StRoKer Oil preference  (Read 2559 times)
nivvy
« on: August 22, 2007 - 12:45:18 PM »
My 499 has on 390 miles on it only and I am running castrol 5w 30.... should I put in something else after a certain mileage??? seems to be a interesting topic lately..... dont want my motor going bad for when I race cuda guy... :burnout:
Re: 499 StRoKer Oil preference
« Reply #1 on: August 22, 2007 - 05:35:11 PM »
I'm surprised you are using 5W-30. I would never think to go that thin in my car.  :lol:
Offline matt63
« Reply #2 on: August 22, 2007 - 08:15:16 PM »
At normal operating temps (210F) the viscosity of 5W30 is the same as 10W30.  The first number (5) only applies to low temp properties ie it acts like 5 weight when it is minus 20F.
Matt in Edmonton
'68 Valiant
Offline Morris'_Mopars
« Reply #3 on: August 22, 2007 - 08:20:23 PM »
I run 20-50w
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #4 on: August 22, 2007 - 09:53:53 PM »
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #5 on: August 22, 2007 - 11:04:13 PM »
If your going to try to out run me I would have 20-50w!     :aarg:
Cuda Guy
Member Since January 14, 2002
« Reply #6 on: August 22, 2007 - 11:42:39 PM »
I run royal purple 10 w in my race engine 499, and in my other 499's that are under 800 hp I have always run penzoil straight 30 weight. But it is z7 high sulfer I think it's called and getting very hard to find. Never had a failure, but street use I changed it every 300 hard miles and track use I changed it every 20 passes. But it never failed under extreme conditions. On our big 3500 hp blown injected engines in the demon and draggster my partner and I bought/built and he runs, we use 3 weight royal purple for less drag. I believe royal has a zero weight also. I forget the weight we use in the rear ends but it's less than 10w too.
Offline matt63
« Reply #7 on: August 22, 2007 - 11:48:08 PM »
in very high hp motors you need high viscosity to provide full film lubrication during very high loads.  I heard (maybe incorrectly) that the nitro engines were running 70W???  If the oil is too viscous you'll have trouble getting it where it needs to go especially when the engine is cold.
Matt in Edmonton
'68 Valiant
nivvy
« Reply #8 on: August 23, 2007 - 12:13:24 AM »
Cuda Guy
I might be able to out run that cuda... gotta get new nike's though for traction.... :smilielol:
  • Pearl Harbor, HI
    • C-C.com
« Reply #9 on: August 23, 2007 - 01:19:38 PM »
72 RestoMod Challenger 499 StRoKEr
      Trade For 440 71 Challenger
   Cuda Guy 10.3 at 66 mph   1/8th
   StROkEr     6.9 at 99 mph   1/8th
Very nice!  LOL!!!   :roflsmiley:
Please dont forget I have a 318 (right now)
Cuda Guy
Offline moper
« Reply #10 on: August 24, 2007 - 12:13:14 PM »
The weights are just the opposite. At cold temps, the oil is thicker (40wt) and as the oil temp comes up, it gets thinner (5wt). I too am surprised at using a 5wt oil for anything more than a low rpm grocery car. It flat out isnt enough IMO. My neon runs 15/40...lol. My good stuff now gets Valvoline VR-1 straight 30. There is no SM rated oil that has enough zink in it to work well with flat tappet cams. And that change was only a few months ago.
Offline bb71challenger
« Reply #11 on: August 24, 2007 - 12:20:53 PM »
Isn't it just like it states on the bottle of oil? ON 10/40 it would be 10 on startup and 40 when at operating temperature?
*Brett*
Offline moper
« Reply #12 on: August 24, 2007 - 12:32:57 PM »
other way around. 40 is thicker. Cold is thicker. You used to run thin in winter, and thick in summer. So you may see "40W for better protection when temps are hot". It's the air temps that get hot. The oil gets thin when it gets hot. That's why you always see oil pressure read hot. Thinner=less protection.
« Reply #13 on: August 24, 2007 - 03:19:47 PM »
That's what I thought too.  :banghead:
  Thanks for the education moper.  :wave:
nivvy
« Reply #14 on: August 24, 2007 - 05:47:54 PM »
well you guys got me talked into an oil change...lol this will be the 5th oil change in 400 miles...lol  :burnout: I guess that means I change my oil every 80 miles............gotta keep it fresh for my kills....... :burnout:
