Author Topic: Pulley alignment problem  (Read 554 times)
Offline shatar4
  • 71 Challenger
« on: August 24, 2007 - 08:13:27 AM »
I just bought a set of March pulleys and the crank shaft pulley is in about 1/8th of on inch from lining up with the water pump and alt. What are my options as to fixing this? Can I use a spacer of some kind? If so, who sells them that thin? Thanks.
1971 Triple black 340 Challenger
Re: Pulley alignment problem
« Reply #1 on: August 24, 2007 - 10:52:44 AM »
have you contacted March ?
Offline shatar4
  • 71 Challenger
« Reply #2 on: August 24, 2007 - 12:14:17 PM »
I had tried to contact them last night around 6:00  with there new extended hours till 7:30 and got ahold of their voice mail box which was full. ( a little sarcasm there). I did find a place that sell shims for crank pulleys so I did order them just now. Thanks anyways.
Offline miketyler
    • www.miketyler.net
« Reply #3 on: August 26, 2007 - 10:34:36 AM »
If the shim plate doesn't work for you you should contact them. They have pulleys with some dimensional variations that could work for you that arent in their catalog on on their website. I went thru the same thing with them when I was setting up my SB.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
