Author Topic: manuals  (Read 697 times)
Offline 73dce
manuals
« on: August 24, 2007 - 08:50:45 PM »
Just wondering if there are any parts books or manuals that show what parts go where and sizes of bolts and such?  Bought my 73 Challenger already disassembled and dont know how they go back together.  I wont be getting to it til after I finish my 66 dodge d200, but would like one now nonetheless.  Thanks.
nivvy
Re: manuals
« Reply #1 on: August 24, 2007 - 08:55:23 PM »
RB/B Engine Torque Specifications Big Block Chrysler 383, 400, 440
* Torque values shown are in ft/lbs unless otherwise noted
* Follow factory torque sequence
 Fastener
 Torque Thread Size
A/C Compressor to Engine Bolt 30 3/8-16
Alternator Adjusting Strap Bolt 200 in/lbs 5/16-18
Alternator Adjusting Strap to Block Bolt 30 3/8-16
Alternator Mounting Bolt 30 3/8-16
Camshaft Lockbolt 35 7/16-14
Carburetor to Manifold Nut 7 5/16-24
Clutch Housing Bolt 50 7/16-14
Connecting Rod Nut - Plain 45 3/8-24
Crankshaft Rear Seal Retainer 30 3/8-16
Crankshaft Bolt (Vibration Damper) 135 3/4-16
Cylinder Head Bolt 70 7/16-14
Distributor Clamp Bolt 15 5/16-18
Exhaust Manifold Nut 30 3/8-16
Exhaust Pipe Flange Nut 50 7/16-20
Exhaust Pipe Clamp Nut 20 3/8-24
Fan Attaching Bolt 15-18 5/16-18
Flywheel Cover Bolt 7 1/4-20
Flywheel Housing to Block Bolt 50 7/16-14
Flywheel to Crankshaft Bolt 55 7/16-20
Fuel Pump to Block 30 3/8-16
Intake Manifold Bolt 40 3/8-16
Main Bearing Cap Bolt 85 1/2-13
Oil Pan Drain Plug 20 1/2-20
Oil Pan Bolt 15 5/16-20
Oil Pump Cover Bolt 10 5/16-18
Oil Pump to Block Bolt 35 3/8-16
Rocker Shaft Bolt 25 3/8-16
Spark Plug 30 14mm
Starter Mounting Bolt 50 7/16-14
Timing Cover Bolt 15 5/16-18
Torque Converter Housing Bolt 30 3/8-16
Torque Converter to Flexplate Bolt 270 in/lbs 5/16-24
Valley Pan End Bolt 9 1/4-20
Valve Cover Stud & Nut 7 1/4-20
Vibration Damper Pulley Bolt 200 in/lbs 5/16-20
Water Pump to Housing Bolt 30 3/8-16
Water Pump Housing to Block Bolt 30 3/8-16
nivvy
Re: manuals
« Reply #2 on: August 24, 2007 - 08:55:54 PM »
LA Engine Torque Specifications Small Block Chrysler 273, 318, 340, 360
 Fastener
 Torque Thread Size
Clutch Housing Bolt 30 3/8-16
Cylinder Head Bolt 273-318 85 1/2-13
Cylinder Head Bolt 340-360 95 1/2-13
Flywheel Cover Bolt 100 in/lbs 1/4-20
Intake Manifold Bolt 35 3/8-16
Oil Pump Cover Bolt 95 in/lbs 1/4-20
Rocker Shaft Bolt 30 3/8-16
Spark Plug 30 14mm
Timing Cover Bolt (cast) 30 3/8-16
Water Pump to Block Bolt 30 3/8-16
nivvy
Re: manuals
« Reply #3 on: August 24, 2007 - 08:56:12 PM »
 :eek2:
Offline Super Blue 72
    • Phil's Super Blue '72
Re: manuals
« Reply #4 on: August 24, 2007 - 10:02:51 PM »
Call Tom Manzi in MA, he may still have a '73 parts manual for sale.  I don't know if he's able to ship it.
http://boston.craigslist.org/nwb/pts/401764335.html
The parts manuals are nice but don't expect an exploded diagram of everything.  They are still nice.  Parts manuals on CD can be found Ebay for like $35 or so.  They don't get into each little nut and bolt size.  The actual parts books vary in price.  Tom is selling them for $50 each or $30 each if you by 5 or more.  I think on Ebay these can get very expensive depending on the year.
Get the service manual too as it'll have lots of nice diagrams.  They can also be found on Ebay either in book form or CD.  :thumbsup:
