Author Topic: Flywheel and pressure plate...  (Read 2287 times)
Offline 71bigblock
    • Steve's Mopars
« on: August 25, 2007 - 06:41:28 PM »
Will this:
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=766
Work with this:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HAY%2D50%2D105&N=700+4294908110+115&autoview=sku
For a 5.7 Hemi with manual 5 speed?  I got a 5 speed from a 2002 Ram 1500, so I would just get the correct clutch disc.
 :feedback:
Thanks   :wave:
« Last Edit: August 25, 2007 - 06:45:21 PM by 71bigblock »
Re: Flywheel and pressure plate...
« Reply #1 on: August 26, 2007 - 11:50:24 AM »
the 2 will work together , I would use a 10.95" disc though , but I do not know if the 8 bolt flange is the same on the newer 5.7 hemi
Offline 71bigblock
    • Steve's Mopars
« Reply #2 on: August 26, 2007 - 05:08:41 PM »
Thanks CP.  Here is the one that they say is for the 5.7, but what would the difference be?
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=1602
Is an 8 bolt flywheel an 8 bolt flywheel?  ???
Offline 71bigblock
    • Steve's Mopars
« Reply #3 on: August 26, 2007 - 05:32:33 PM »
And this disc combined with the Hays clutch, and the above flywheel.  ???
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_24678_-1
« Reply #4 on: August 26, 2007 - 09:19:13 PM »
not nessisarily , the 2.2 also has an 8 bolt flywheel but with a miniature bolt pattern , I do not have a 5.7 flexplate to check the pattern
Offline 71bigblock
    • Steve's Mopars
« Reply #5 on: September 03, 2007 - 05:44:48 PM »
Bumping this with another question:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AX%3ARTQ%3AUS%3A11&viewitem=&item=200148004163
Are pressure plate bolt patterns standard?  Will this work with the 5.7 specific flywheel?
« Reply #6 on: September 04, 2007 - 01:30:01 AM »
I cannot answer that , try contacting Red & McLeod , they should know what will work for you
Offline 71bigblock
    • Steve's Mopars
« Reply #7 on: September 04, 2007 - 01:09:18 PM »
I contacted RAM Clutches, and this is what they had to say:
Quote
Steve,
I don't normally like to comment on ebay items, but a 401 pressure plate has
a bolt circle of 11.625" measure the bolt pattern on your flywheel to see if
it will bolt on. This is assuming that what he is selling is indeed a 401
pressure plate,like he said was.
Doug
RAM TECH
So with an 11 5/8 bolt circle, will it bolt up to that flywheel?  Or do I have to order it and measure it?  I could go and check my 318 flywheel, maybe they have the same pattern.
Thanks for your patience and knowledge CP.   :grinyes: :2thumbs:
« Reply #8 on: September 05, 2007 - 02:45:29 AM »
there are 2 patterns I know of , the Long style with 3 pairs of bolts close together & the Borg & beck style with 6 eqaul spaced bolts , if you can see the pattern on the flywheel & it is equal spacing the clutch will bolt on if it is a B&B style
