Author Topic: Ebody clutch linkage + gear vendors overdrive  (Read 3637 times)
Offline 0tter45
« on: August 25, 2007 - 09:36:50 PM »
Hello all i was wondering if anyone out there has photos, of the  correct zbar clutch linkage installed on an ebody.   Iam in the process of making things right on a 74 barracuda.   It had A body A833 transmission installed and iam rounding up the proper parts, longer tail housing, output shaft, rods, ect.  I plan on going with 1 7/8 tti headers and 3 inch exhaust in the new year so i want to make sure i get the clutch linkage right the first time.
My second question,  is there any one running a gear vendors over drive on a A833 in an ebody.  Iam interested hom much modification  is required to the floor tunnel.
Regards,
Otter
Offline cudabuyer
Re: Ebody clutch linkage + gear vendors overdrive
« Reply #1 on: August 26, 2007 - 06:30:53 AM »
 i have the 833 mated to the gvo all behind a 6.1 hemi
4 questions please call http://custom-musclecars.com/ talk to Shane
should have the car running for the first / second time with a new engine
Sorry guys - installed / removed / sold the 540 aluminum hemi
recently installed the 6.1 hemi, waiting for pics from the resto shop   :working:  for 20 months sometimes S&i! happens   :money:
70 Dodge Challenger Convertible 6.1 Hemi
Offline 0tter45
« Reply #2 on: August 26, 2007 - 10:48:11 AM »
That definetly is a nice toy you got going there.  I hope you get it out of the shop soon and get to do some driving. There are a few photos of the gear vendors over drive installed.  But maybe i will give shane a call and see what kind of mods he did to the floor tunnel.   I will not be buying anything till the new year now so maybe i can get some info from you later on as to how you like it.  Thanks for the info!!
Otter
Offline 0tter45
« Reply #3 on: August 26, 2007 - 09:25:06 PM »
Hello Chryco i was wondering if you could take some photos the next time you weld in the brackets for z bar linkage on an ebody!! I want to make sure i get everything imstalled corectly!   Also have you ever installed a gear vendors iam curious how much beating i would have to do on the floor to get it to clear. Thanks!!
Otter
« Reply #4 on: August 26, 2007 - 09:26:40 PM »
I have not installed a GV unit , only the 833 OD & Keisler
 I can take some pix but I am sure someone will post before I get to it
Offline 0tter45
« Reply #5 on: August 26, 2007 - 10:15:06 PM »
Chryco if you had a choice which way would you go?  Kiesler or go with a gearvendors on a A833?  Do you own your own shop out in Alberta?
Otter
« Reply #6 on: August 26, 2007 - 10:31:41 PM »
well there are reasons to do & not to do both
 I really hate dealing with Keisler too many lies / broken promoses & problems with the product , but it will fit better than trying to cut the tunnel to fit the GV , I feel the GV is a better product & will give you more gears as well though
 No I do not have a shop , for4 the last 4 years I have done mobile work at customers places but now I am basically done , I cannot make enough $$ anymore here & the winters are too long with no work to survive , I cannot get into the US , so it either time to move to Panama or get a real job , right now I am basically homeless & living in Moms spare bedroom / couch
Offline 0tter45
« Reply #7 on: August 26, 2007 - 10:42:41 PM »
Albertas pretty busy right now iam sure you could make more money twisting wrenches in the oil patch and full time work.  but then again its pretty pricey out there for a house.  Is it not about $400,000 for a starter home in Calgary these days.  If it was me thou i would go a little bit farther south than Panama if i was heading south.  Lots of cute girls down there and you would be suprised of all  the old mopars in good shape in south america.
Otter
« Reply #8 on: August 26, 2007 - 11:22:03 PM »
actually a lot of people I know are layed off right now due to the oil patch trying to choke down prices & with no certification it is not as easy as you think to get good paying work
 yeah a starter house is over $400k right now
Offline basement
« Reply #9 on: August 27, 2007 - 06:09:09 PM »
This is the best i could find.
Offline 0tter45
« Reply #10 on: August 27, 2007 - 11:43:23 PM »
Thanks alot basement the photos are very much appreciated.  Would you happen to have one of the z bar where it attaches to the tranny.  I want to make sure i have at least the right bracket on the tranny Thanks again !!
Otter
Offline basement
« Reply #11 on: August 28, 2007 - 05:11:33 AM »
a little blurry but maybe they'll help
Offline basement
« Reply #12 on: August 28, 2007 - 05:16:36 AM »
The pics don't show the entire bracket on the tranny side. It's just a ball type that screws into the transmission. I bought a z-bar rebuild kit and it came with the new 'ball' brackets and bushings/seals/clips/keeper spring.
« Reply #13 on: August 28, 2007 - 10:52:30 AM »
most do not use a bracket on the engine side , is your combo small block or big block , I have seen the bracket used on some small block installs
Offline 0tter45
« Reply #14 on: August 28, 2007 - 02:29:45 PM »
mine is a small block but i think the bracket on the tranny is for a Abody!!
