Author Topic: Holly carb/throttle bracket needed  (Read 649 times)
Offline RUSTY Cuda
  • One big step foward!
« on: August 26, 2007 - 05:33:52 PM »
Trying to hook up the kickdown linkage I bought & we are missing a bracket off the carb & also the front manifold bracket to hook the springs up to. it's a 360 motor, carb is a holly 650 I think # 3310
I got this pick off the holly site but it may not be the exact one(different carb #) but it gives you an Idea what I need. Thanks,Rich.
Offline 71HotRod
Re: Holly carb/throttle bracket needed
« Reply #1 on: August 26, 2007 - 08:04:57 PM »
#3310-1 is a 780cfm,-2,3,4 is a 750 cfm.there is a aftermarket throttle spring brkt. that bolts to carb base, clean and simple. ck summit,jegs,or local speed shop.they should be able to help with brkt. also. Dave
