My 540ci Hemi Build
Author Topic: My 540ci Hemi Build  (Read 33013 times)
Offline 1BADFISH™
Re: My 540ci Hemi Build
« Reply #120 on: January 11, 2008 - 03:54:44 PM »
 :worshippy  Looks awesome Carl!   :burnout:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline Carlwalski
« Reply #121 on: January 11, 2008 - 08:08:41 PM »
That is the most thing I like about HEMI's othe than being a HEMI you can make a hemi look so much like stock its sickning....
That is a real good point Stroker. I've never really thought about that. I know you can make a 440 stock though with BIG hp, just take the Year One F.A.S.T class for instance. But a big % of the cars have big filters, heads, chrome, MSD ignitions and boxes etc so ti's not as easy for them, I guess? :dunno:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
nivvy
« Reply #122 on: January 11, 2008 - 09:01:26 PM »
not to mention with high lift cams / rockers you need taller valve covers... unless you do the double gasket trick.... but mostly the intake is a dead giveaway even if you paint it like the block.....
just curious if they gave you the head flow numbers and cam specs... I wanna punch them into my camquest program to see if it matches real close to the engine dyno like mopar muscle test did was in within 4 hp on the camquest program compared to the actual engine dyno ???
Im real curious how close it is to yours.....  :2thumbs:
« Last Edit: January 11, 2008 - 09:04:15 PM by StRoKer »
Offline PasiR
« Reply #123 on: January 18, 2008 - 04:55:27 AM »
Hi Carl. Awesome motor, real TORQUE monster.  :worshippy I have stopped progress with my 472 iron elephant and probably will sell it soon, I mean just a short block. I have been too many times here to watching pics and specs of your beast, so I contacted Tim...
Offline Carlwalski
« Reply #124 on: January 21, 2008 - 07:54:28 AM »
You'll be glad you made the call, his workshop and work are immaculate, best of the best. ;) :thumbsup: For anyone interested, I just update my www.carlwalski.com/Madeline3.html with 5 pages of photos from start to finish of the build. All photos were taken by Tim, they do that for each build for the customer along with other stuff like dyno videos etc.
:cheers:
Offline Carlwalski
« Reply #125 on: January 21, 2008 - 07:57:57 AM »
Hey Carl, :blah:
                 Next time you are chin wagging with the boys at FHO ask them to e-mail or fax the cam card details on to you please.  I would be interested to know the grind they put in your 540 Hells Bells Hemi. :ylsuper:
Kenny. :2thumbs:
Tim just sent me the following, he's been pretty busy (as you'd expect).
Anyhow, here is the following info he sent me on my Hemi build.
C.B. 540 C.I. EFI Hemi Engine Specs
Block Casting:   KB Aluminum Street Water Block
Block Machining:   Block machined to specs. Block de-burred and pushrod holes enlarged.
   CK10’d with deck plates to final bore size.
Deck Height:   10.725”
Bore Size:   4.505”
Stroke:     4.250”
Pistons:   Custom CP Forged    10 to 1 Compression Job #72604
Compression Distance   1.49”
Clearance:   .006” Measured ½” up from skirt, 90 degrees from pin.
Pins:   CP Tool steel .990” x 2.930”
Locks:   Tru-Arcs ( double )
Rings:   1/16x1/16x3/16” Custom Gapped    CML9190-255
Ring Gaps:   Top .019”,   2nd  .018”, Oil .020”
Crankshaft:   Ohio Forged 4.250” Stroker
Crankshaft Machining:   Balanced and polished.
Crank Journals:   2.1995”
Crank Mains:   2.7492”  M142  ¾ Groove Bearings
Crank Clearances:   End play:  .004”.   Mains:  .0025”.   Rods:  .0025”        Side Clearance:  .022”
Connecting Rods:   FHO 7.100” H beam.
Rod Prep:   Balanced and bushed from manufacturer
Rod Bolts:   Torque to 60lbs. with moly.
Pickup to oil pan:   .125”
Camshaft:   Competition-Cams custom Hydraulic Roller  240-244-112
   Theoretical lift at 0 lash.               Intake- .566”  Exhaust- .533”
Cam Centerline:   112 degree installed centerline. .035” shim upper gear for alignment.
Valve Lash:   O Lash plus ½ turn
Heads:   Stage V Aluminum Replacement
Head Machining:   Hone Bronze-alloy guides, full-radius valve job, surfaces machined, open up
   bowls and street porting.
Combustion Chamber   172 cc
Head Gasket:   .051” Cometic Multi-Layer
Valves:   2.25” Manley Stainless Intake
   1.90” Manley Stainless Exhaust
Seats:   Intake- .040”x 45 Full Radius and 060” x 45 Full Radius Exhaust
Face:   .080” x 45
Valve to Valve   .265”
Valve Springs:   Comp-Cams #929 Doubles with damper. CC741-16 Retainers
Installed Height:   1.880” @ 140 lbs. Seat pressure
Keeper to Guide Clearance:   .750”Plus  Manley 10 Degree Locks. 307.5” exhaust/308.5” intake.
Clearance to Coil Bind:   .130”Plus
Valve Guides:   Bronze Alloy .0018” Intake and .0022” Exhaust Clearance
Valve Seals:   CC509-16 Viton
Piston to Head Clearance:   Minus .010” outer ring without gasket
Valve Clearance:   .200” plus intake and .300” plus exhaust
Rockers:   Stage V Stainless 1.6 ratio roller rockers
Push Rods:   Manton Custom 3/8”HD
   Intake OAL = 9.900”   Exhaust OAL = 10.700”
Intake Manifold:   Stage V Inline
Intake Machining:   Port match- install injector bungs.
Compression:   10 – 1
Horsepower   See dyno sheet
Offline PasiR
« Reply #126 on: January 21, 2008 - 10:45:17 AM »
Thanks for the specs Carl. Hydraulic roller... I like it.  :ylsuper: :ylsuper:
Offline Carlwalski
« Reply #127 on: January 21, 2008 - 05:07:03 PM »
Thanks mate, keep us posted on your build whom ever you choose to perform it. :cheers:
Offline PasiR
« Reply #128 on: January 22, 2008 - 08:59:07 AM »
Sure  :stirpot:
Offline Carlwalski
« Reply #129 on: February 21, 2010 - 04:36:32 PM »
how about some pics for old time sakes  :2thumbs:
Sure! Why not, here's a couple...........  :cheers:
Offline 67vertman
  • Member since 9-23-2005
« Reply #130 on: February 21, 2010 - 05:49:15 PM »
I forgot hoe pretty she was..... :drool:
Thanks  Mate.  :2thumbs:
« Reply #131 on: February 21, 2010 - 06:01:59 PM »
Very Nice Carl.  :2thumbs:
How's that chrome water neck doing? Is it puking green yet?
Offline Carlwalski
« Reply #132 on: February 21, 2010 - 06:54:19 PM »
Thanks guys, its not the biggest Hemi out there nor the most powerful but I can't wait for the day I can crank it over and here it sing! TC - No coolant coming out. We de-fogged it as per Tim Bannings instructions around 18 months ago and crank it over every month to keep it fresh. Hopefully before the end of the year we'll have it running.
 :wave:
« Reply #133 on: February 21, 2010 - 11:27:43 PM »
which car is that going into ??
« Reply #134 on: February 21, 2010 - 11:34:41 PM »
 :wave:
I'm should be putting mine together in March. Got a link or e-mail on how he told you to fog it?
