Author Topic: Opening up a 'cuda hood.  (Read 4044 times)
Offline Fred
Re: Opening up a 'cuda hood.
« Reply #15 on: August 29, 2007 - 01:59:31 PM »
When idling, at a standstill, air actually flows out the scoops!
If not ducted to the carb, the air may have been from fan pressure under the hood.
What about fabricating 2 smaller items from the scoops shape to a round shape.  Then ducting to the thing that kingtroll posted.  Might be easier to find something to fit in a round duct that could switch between scoop air and under hood air. :dunno:
sleepychallenger
« Reply #16 on: August 29, 2007 - 03:26:21 PM »
I could understand that at a stand still they become heat vents. There is a whole lotta heat under the hood of our cars.
I agree that they may not be high enough up in the airflow to make a big difference in power, but, how big is big.  If they aren't isolated to feed the carb directly, they will actually make no difference at all. A properly sealed fresh air system can remove at least a couple of tenths at the drag strip though. How much of a difference the smallish, low factory scoops make may be pretty minimal.
But it is cool, none the less.
doesnt a cooler engine run better
« Reply #17 on: August 29, 2007 - 03:50:06 PM »
It depends. Cooler intake air makes a big difference. A cooler engine doesn't necessarily make more power. Plus, the heat released through a scoop at idle now becomes drag when the car is moving forward as it packs the engine compartment with additional air that now is exiting under the car creating a higher pressure zone where you want low pressure. You ever watch a Cup team adding and/or removing tape from the nose of a car during a race? You don't want any more air moving through the car than is necesary to keep the cooling system functioning. I doubt any of that is a big impact on an early 70s E body, but just food for thought.
sleepychallenger
« Reply #18 on: August 29, 2007 - 04:30:59 PM »
i just figured that the cooler engine would make the air and engine surroundings cooler
Offline IMNCARN82
  • LeDZeP
« Reply #19 on: August 29, 2007 - 07:18:45 PM »
Yes the scoops do dump alot of air at a stop. They also clear the hot air when your going down the road.They funnel in much more air than you might think. I'm not looking to just toss pieces of aftermarket stuff together to make it work.The scoop for the underside of the hood is almost complete.I've tested three different shapes.Added a metal plate along the mounting points to beef it up.I'm finding the smoothest,cleanest look with a baffle that comes up from the bottom vs. the end. It takes up too much room,looks funny too.  I'm working on a way to switch between letting air go to the carb.,to dump heat out,and to close for wet weather.  This system,once set up correctly will drop down and seal around the carb. when you close the hood. You will be able to choose where the air goes from inside the car.  I have even looked into vacum operated baffles....so when you hit the gas the baffles open,like on a carb.   I thought it was alittle goofy though...
Cutting the cast scoops out was the real hard part. I wanted them to look nice. You could probably do it real nice with a jig and a mill.Mayby someday...
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
sleepychallenger
« Reply #20 on: August 29, 2007 - 10:09:28 PM »
keep us posted, sounds like a great idea and would love to see the finished product  :useless:
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #21 on: August 30, 2007 - 02:17:45 PM »
My scoops are cut out to atleast it lets in some air there when there was none to let in before.
michele
