Author Topic: Engine porn ...  (Read 3546 times)
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Engine porn ...
« on: August 30, 2007 - 11:36:17 AM »
I have had some requests for pictures of my motor, so here
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Engine porn ...
« Reply #1 on: August 30, 2007 - 11:37:32 AM »
more...
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Engine porn ...
« Reply #2 on: August 30, 2007 - 11:38:55 AM »
and more...
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Engine porn ...
« Reply #3 on: August 30, 2007 - 11:39:43 AM »
and finally...
Re: Engine porn ...
« Reply #4 on: August 30, 2007 - 11:52:05 AM »
Wowsa is that a healthy girl!!   :droolingbounce:
Offline Scatterbrain
  • 1973 Challenger
Re: Engine porn ...
« Reply #5 on: August 30, 2007 - 11:53:47 AM »
Sexy is what I'd say.
Offline Mike71Cuda
Re: Engine porn ...
« Reply #6 on: August 30, 2007 - 12:02:49 PM »
Nice injection!
Hey Dog I see it looks like you went with the ready to run setup from MSD fo rdist. How do you like it?
It cleans up the firewall (no ECU) I hav eseen where soem people have taken out ballast res. and others say it a must keep. Are these shots current and without bal.? Great job! Where are other shots of the car?
Smitty
Offline Carlwalski
Re: Engine porn ...
« Reply #7 on: August 30, 2007 - 12:08:46 PM »
Very nice!! Good to see your ankles will be safe with the Lakewood.
Thanks for sharing, definitely an eye catcher!!
:woo:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Engine porn ...
« Reply #8 on: August 30, 2007 - 12:23:30 PM »
Nice injection!
Smitty
I am actually running a MSD 8546 Pro Billet Distributor for Mopar raised blocks with almost all FAST components for EFI.  I just haven't gotten around to mounting the XFI unit yet and have been focused on some of the plumbing and getting the A/C components in the car to see how much room is available under the dash.  If I can't secure it nicely under the dash, I will look at putting in a false floor under the passenger's foot area.  :dunno: I will have to work out the ventilation going that route.  Either way, there is a hole that will need to be cut in the firewall!  :faint:
The rest of the car hasn't changed much from this:
Offline 426HEMI
Re: Engine porn ...
« Reply #9 on: August 30, 2007 - 12:54:48 PM »
I just wish I could get mine looking that good.  I hope I can start to restore it soon.  Not sure when because funds are low.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Re: Engine porn ...
« Reply #10 on: August 30, 2007 - 01:23:59 PM »
Scchhwiiing!!
I
Offline hemi71
Re: Engine porn ...
« Reply #11 on: August 30, 2007 - 05:12:46 PM »
Watch the pinion angle with the keisler setup and the hemi. What motor mounts are you using? I ran into a problem with the 5 speed keisler and the schumacher mounts.
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Engine porn ...
« Reply #12 on: August 30, 2007 - 05:35:15 PM »
I am running the Schmacher mounts as well.  It was the only way I could get this motor in the car without going to a motor plate.  Did you shim the rear, or transmission to correct the issue?
Offline hemi71
Re: Engine porn ...
« Reply #13 on: August 30, 2007 - 06:35:02 PM »
You are the point now where you might be able to shim the trans mount. Hard to tell from the pics, but it looks like the motor is sitting a little low in the back. My problem was i could not shim the rear trans mount as the trans started hitting the floor before i could get the neccessary 1/2 inch shim in.
The keisler by itself is known to have problems, and sometimes so do the schumacher mounts...together they just compound the problem. I did have a hemi with the schumacher mounts and a 833 4 speed and that was fine. Only problem i had with that setup was the dipstick tube did not clear the mount, and had to be modified and the dipstick remarked...not a big deal.
BTW...engine/car looks GREAT!
 :cheers:
Offline 70RAGTOPR/T
Re: Engine porn ...
« Reply #14 on: August 30, 2007 - 07:13:41 PM »
Real Nice!!!!!!!!
