Speedometer Pinion Gears help need again.
Author Topic: Speedometer Pinion Gears help need again.  (Read 6265 times)
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Speedometer Pinion Gears help need again.
« Reply #15 on: September 02, 2007 - 08:13:22 PM »
badly wore out  speedometers can also read incorrectly. if the odometer is reading correct that maybe your problem.
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #16 on: September 08, 2007 - 01:45:21 PM »
I jack up the car today. And had a budy turn the wheel one turn around. I counted the turns of the drive shaft and it was 3 and 1/4 turns. Used the U-joint end to count with. So that mean I have 3.23, right?
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
