Author Topic: air filter size  (Read 690 times)
Offline 72Chall77Doba
  • Bill's Mopars
    • My Car Domain Page
air filter size
« on: September 01, 2007 - 12:30:46 AM »
I'm in the process of having my 72 restored and they replaced the air filter with a much thinner one, in height.
How will this affect the engine in terms of performance and mpg. I used to get 7 mpg.
318 with a 4 bbl holley double pumper.
Offline PlumCraZRT
Re: air filter size
« Reply #1 on: September 01, 2007 - 01:26:03 AM »
Put a regular air filter on if you're concerned about it.  In theory it could hurt your performance and gas mileage, but probably not a whole lot.  Better question is why you have a double pumper on a 318?  That's hurting your mileage worse than any airfilter could.  Unless you have 4.51 gears and a tranny that slips more than a roller skater in a ball bearing factory, a 625 cfm vacuum secondary carb that is well tuned should put you more in the tune of 15 mpg.  Such a small motor shouldn't struggling to get 10+ mpg.  You're not driving everywhere in reverse are you?   :roflsmiley:
mmmmm.... Mopar.... *drool*
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: air filter size
« Reply #2 on: September 01, 2007 - 02:10:06 AM »
7 mpg with a 318  :faint:
Unless this is a high rpm race motor, you should be at least in the teens
Re: air filter size
« Reply #3 on: September 01, 2007 - 02:49:32 AM »
lose the filter , it has to be restricting the flow
 as for the 7 MPG something is not right
nivvy
Re: air filter size
« Reply #4 on: September 01, 2007 - 12:04:18 PM »
 :iagree: Stock 440375/HP cars got 13mpg  :22yikes:
Re: air filter size
« Reply #5 on: September 01, 2007 - 12:12:15 PM »
Several years ago, one of the magazines did air flow testing on various sized filters. I think the minimum size they used before power started falling off was a 14" round and 3" tall unit. Anything smaller than that hurt output, but i don't recall the amounts.
As far as power and mileage, give us some more specs onthe engine. You might have too big a cam and too big a carb with too low compression for you combo.
