Updated: Coil question... And distributor question
Author Topic: Updated: Coil question... And distributor question  (Read 3161 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: September 01, 2007 - 04:07:15 PM »
On my 70 'cuda 383 I have a Mallory dual points distributor (part no 2557701) and a PerTronix Flame Thrower II coil. Does this coil match the distributor? I don't have a ballast resistor. I was thinking of getting the Mallory Coil (part No 29217).  Do I need ballast resistor then?  The reason I want to switch the coil is that I have trouble starting my 'cuda when it's cold, even during the summer.
« Last Edit: September 08, 2007 - 05:26:46 AM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Coil question...
« Reply #1 on: September 01, 2007 - 05:01:11 PM »
Your problem is possibly related to power loss in the electrical system, check your voltages to the coil in the start mode & see if it's much below 12 Volts. If so cleaning burnishing plugs & contacts may help, a local club member engineered a relay to solve his problem.
read about it here http://www.tvmoparclub.com/files/tech/Quick%20Start%20Relay.pdf
Offline widing'cuda
« Reply #2 on: September 01, 2007 - 05:19:43 PM »
OK, I'll check that. So the PerTronix Flame Thrower II coil should work with my dual point distributor, without any problems?
« Last Edit: September 01, 2007 - 05:21:19 PM by widing'cuda »
« Reply #3 on: September 02, 2007 - 02:22:41 AM »
yes the coil should work , probably not the best system though
Offline widing'cuda
« Reply #4 on: September 02, 2007 - 05:28:48 AM »
Will it work better with a Mallory coil. Or should I just replace the distributor and coil with a better electronic system, like Mopar Performance or MSD?
« Reply #5 on: September 02, 2007 - 01:13:28 PM »
I would look into replacing the dist with a electronic one , the coil is fine
Offline widing'cuda
« Reply #6 on: September 02, 2007 - 03:54:07 PM »
Ok, I'll look into that. I replaced the spark plug wires today and that did wonders. It starts much easier now. But I'll look into replacing the dist anyway.
« Reply #7 on: September 03, 2007 - 06:15:04 PM »
  I know it will cost you some money, but at least the electronic ignition will be more efficient, and not need any adjusting as with the points system.
Offline moper
« Reply #8 on: September 06, 2007 - 09:49:49 AM »
With no resistor, you may simply be wearing outt eh points faster than normal. All that means is you should own a dwell meter, and spend some quality time under the hood more often. Hard starting is a possible sign of worn points, and setting point gap is not really very accurate. I'd simply use the right procedure and set the dwell on each set of points, possibly file or replace them, and see what it does. Or, you can upgrade to any electronic.
Offline widing'cuda
« Reply #9 on: September 06, 2007 - 05:25:04 PM »
Any suggestions to from who? Is the one from Mopar Performance any good?: http://store.summitracing.com/partdetail.asp?autofilter=1&part=DCC%2D3690427&N
« Reply #10 on: September 06, 2007 - 06:10:02 PM »
That's the basic system right there, but some people have had trouble with that orange ignition box since it is now made in China.  :eek4: My electronic ignition system came from FBO.  4secondsflat.com
Offline widing'cuda
« Last Edit: September 07, 2007 - 05:44:52 PM by widing'cuda »
Offline MyMopar
« Reply #12 on: September 07, 2007 - 01:23:23 PM »
What about these:
Or MSD
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D8545
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D6420
The box is great and I think that is the distrib. I have, MSD pro billet.  Starts nice, has plenty of spark power and the adjustability is good.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline widing'cuda
« Last Edit: September 08, 2007 - 05:25:09 AM by widing'cuda »
Re: Updated: Re: Coil question... And distributor question
« Reply #14 on: September 09, 2007 - 04:19:34 AM »
What's the difference between the to system I have listed here? What would you guys suggest?
1:
2:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D8386
 the second system is a self contained system not needing an external ing box to work with the dist
