383 buildup need some opinion!!!
Author Topic: 383 buildup need some opinion!!!  (Read 1166 times)
Offline 1968mopar383
« on: September 01, 2007 - 09:00:08 PM »
hi ....first sorry for my english...im a french speaking!!...ok..im curently building a 1968 383...here is the part list....stock crank.. polish and new bearing...edelbrock camshaft:        Duration at 0.006" Lift: Intake: 300° Exhaust: 308°
Duration at 0.050" Lift: Intake: 238° Exhaust: 246°
Lift at Cam: Intake: 0.320" Exhaust: 0.330"
Lift at Valve: Intake: 0.480" Exhaust: 0.495"...with matching valves springs....edelbrock double roller timming chain...edelbrock torquer aluminium intake.....edelbrock 750 cfm performer series....full length hedman headers 1 7/8 ..3'' out....906's with little porting....(88 cc)...2400 torque stall..2.76 rear gear soon to be swap for 3.23 sure grip....and my question is......which pistons do i have to buy to have a good compression...like 9 or 9.5 ratio and....is my combo sounds good ??? thanks .....
Re: 383 buildup need some opinion!!!
« Reply #1 on: September 02, 2007 - 02:28:42 AM »
Speed Pro makes a forged flat top piston that will get you ion the mid 9 : 1 range depending which thickness head gasket you use , I do not have the part # handy right now
kudakidd
« Reply #2 on: September 06, 2007 - 07:37:33 PM »
Your combo sounds fine. You may want to mill the heads a bit to reduce the 88cc volume
Offline oldkimmer
« Reply #3 on: September 07, 2007 - 02:05:31 AM »
Toss that junker cam, go with comp or some other good name brand..........kim.......... :canada:
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: September 08, 2007 - 01:42:56 AM »
That is a big cam for a 383, I have the same one in my 440 and it likes a 2800 stall and 3.55 or 3.91's. With the 383 you need a higher stall speed than 2800 or it might be pretty sluggish.
