Author Topic: Yet another Painless wiring question.  (Read 2232 times)
Offline shatar4
  • 71 Challenger
« on: September 02, 2007 - 09:51:06 PM »
On the headlight section, I am wiring up the side markers, turn signals/marker lights in the front. The manual shows:
wire 927 (grn/red) going to the Parking lights
wire 927 (grn/blk) going to the marker lights
wire 925 going to the right front turn signal.
My question is I have one side marker light and one turn signal on each side. How do I hook up these wires so I have running lights and a turn signal? Is there not a marker light up front until you tun on the turn signal? There is only 2 wires on each pig tail and one of those are a ground wire. Any help would be awesome!
« Last Edit: September 03, 2007 - 01:26:49 AM by shatar4 »
1971 Triple black 340 Challenger
Re: Yet another Painless wiring question.
« Reply #1 on: September 03, 2007 - 01:57:02 AM »
you front lights will have 2 wires 1 is turn [brighter]connect 925 to this  & 1 is park [dimmer]connect 927 here , ground is through the housing  , the side lights hook top the other 927 wire &should ground through the housing also , there is no turn signal on the side light
Offline shatar4
  • 71 Challenger
« Reply #2 on: September 03, 2007 - 08:27:48 AM »
I know there is no side turn signal but if one wire connects to 927, where does the other wire conect to?
« Reply #3 on: September 03, 2007 - 12:35:39 PM »
you have 2 wires from the side lights ?
Offline shatar4
  • 71 Challenger
« Reply #4 on: September 03, 2007 - 05:31:39 PM »
Yes I do.
Offline GoodysGotaCuda
« Reply #5 on: September 03, 2007 - 05:42:18 PM »
You should have.
A pair of front turn signal/parking lights up front. Three wires, ground, parking,and turn.
A fender top turn signal thats grounded through its case, and has a feed off the turn signal wire from the front marker(from the right side)
A pair of side fender parking lights that feed off that parking light wire that goes to the front markers
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline shatar4
  • 71 Challenger
« Reply #6 on: September 03, 2007 - 05:47:33 PM »
I have no fender top turn signals.
