Author Topic: Gas Filler Neck  (Read 2782 times)
Re: Gas Filler Neck
« Reply #15 on: September 10, 2007 - 12:50:53 AM »
. Used KY jelly (that just doesn't sound right though, does it?) for lubrication, then tightened the strap
Did you say sweet things to it 1st?
Offline dawgs 73
Re: Gas Filler Neck
« Reply #16 on: September 10, 2007 - 01:38:55 PM »
Nah, bought flowers.........  (hooh boy, this is getting really ugly here. Funny, but ugly)
Re: Gas Filler Neck
« Reply #17 on: September 10, 2007 - 04:56:38 PM »
Offline dawgs 73
Re: Gas Filler Neck
« Reply #18 on: September 10, 2007 - 06:07:51 PM »
Bullitt, you're killing me here.
Offline DAYLEY/CHALLENGER
Re: Gas Filler Neck
« Reply #19 on: September 21, 2007 - 11:23:49 PM »
I had the same problem when I put mine back on.  Finally lowered the tank and got a straight in shot with the tube.  Took a while though.
Dave or David
Offline LAA66
Re: Gas Filler Neck
« Reply #20 on: September 22, 2007 - 10:17:23 AM »
 Your right DAYLEY, the angle is most important. We tilted the opposite side of the tank downward a bit and it worked fine. Don't forget to fit the trunk seal first or:hyper::swear:  Also mask the filler neck to help prevent scrathing it on the trunk floor.
 It seems the straps can be over tightened too. Once the 90 at the j-hook starts to bend upwards, that is enough.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Gas Filler Neck
« Reply #21 on: September 22, 2007 - 02:45:34 PM »
 :iagree:  :iagree:  :iagree:
The angle is soooo important.  When I was tugging on the tank from underneath it was impossible to get it out!!!
When I angled the tank so the far end was on the ground and the side where the filler neck went in was close to the hole in the trunk pan, I just twisted as I pulled and it came out in lterally 10-15 seconds!!!
Twisting while pulling helps, along with lots of WD-40!!!
