mopar 383 dome piston????
Author Topic: mopar 383 dome piston????  (Read 1238 times)
Offline 1968mopar383
« on: September 03, 2007 - 12:29:59 PM »
hi guys....i have a 383 with a mild setup...stock crank.. polish and new bearing...edelbrock camshaft:               Duration at 0.006" Lift: Intake: 300° Exhaust: 308°
Duration at 0.050" Lift: Intake: 238° Exhaust: 246°
Lift at Cam: Intake: 0.320" Exhaust: 0.330"
Lift at Valve: Intake: 0.480" Exhaust: 0.495"...with matching valves springs....edelbrock double roller timming chain...edelbrock torquer aluminium intake.....edelbrock 750 cfm performer series....full length hedman headers 1 7/8 ..3'' out....906's with little porting....(88 cc)...2400 torque stall..2.76 rear gear soon to be swap for 3.23 sure grip....and my question is that i want to put some kb400 .30 oversize....+6.26cc dome....do the pistons will fits with 906 heads and 0.021 head gaskets and how much compression will it makes....thanks....any suggestion be appreciated!!!!
Re: mopar 383 dome piston????
« Reply #1 on: September 04, 2007 - 01:38:55 AM »
there are online compression calculators where you can add all the info you have & determine the ratio , just Google compression calculators
Offline moper
« Reply #2 on: September 06, 2007 - 09:57:24 AM »
Well, I'm guesing on the head ccs and the actual deck height of the pistons. If they go in at what i'd say is average, they'll be in at .020 down or so. Guessing again on the inbtake valve closing point at .050 lift, I get a static of about 9.6:1, and dynamic of about  8:1. If they are at 0 deck, the static goes over 10.1:1 and the dynamic goes to 8.4:1. So it will depend on the deck height, and your cam choice as to whether or not it is pump gas friendly. I wouldnt run the Edelbrock cam. There are muc hbetter out there, and I'd sacrifice static ratio for a better cam.
