Author Topic: Pinion Snubber Needed?  (Read 892 times)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« on: September 03, 2007 - 06:12:29 PM »
I have seen many cases where people use Dana 60's out of trucks and put them on their e-body these housings do not have the pinion snubber.  My question is does it matter if it has one?  The application would be street/strip use.  What have you guys experienced?  I know Neil can weigh in on this one.
Cuda Guy
Member Since January 14, 2002
nivvy
Re: Pinion Snubber Needed?
« Reply #1 on: September 03, 2007 - 06:40:04 PM »
Not having a pinion snubber is breaking a mopar golden rule.... you will never be able to beat me without one.... :aarg:
« Reply #2 on: September 03, 2007 - 07:16:33 PM »
I suggest you get 3 or 4....& smoke the sTRoke
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: September 03, 2007 - 11:45:51 PM »
I have an adjustable one I will sell you  . . . brand new condition.   :grinyes:
« Reply #4 on: September 04, 2007 - 01:28:12 AM »
the snubber helps a LOT at the track  but gives a horrible ride on the street , the floor in really strong enough to take the pounding of the snubber on a long term basis but you can weld a bridge into the tunnel above the diff with a threaded snubber to do the same thing
« Reply #5 on: September 04, 2007 - 07:21:59 AM »
The only time I've ever benefited from having a snubber was when I was putting lots of horses down and was using a stock rear suspension. The power tended to override the springs ability to hold things down and the snubber helped resist that rotation. After switching to the proper SS springs, the snubber because worthless as the springs now created enough body seperation that I never used the snubber.
FWIW, Fox bodied mustangs also use a snubber, but it bolts to the body pan instead of the axle.
