Author Topic: Engine Support Bar  (Read 969 times)
Offline Grundy
Engine Support Bar
« on: September 04, 2007 - 11:37:48 AM »
Anyone ever use one of these to do work on their E-bod engine?
Something like this: http://www.sjdiscounttools.com/otc4324.html
Did you use something different? If so, what?
Thanks
Drive it like you stole it.
Re: Engine Support Bar
« Reply #1 on: September 04, 2007 - 01:35:29 PM »
I've used 3" steel I beam before.
Offline Grundy
« Reply #2 on: September 04, 2007 - 01:42:16 PM »
How did you support it on either side? Right on the fenders?
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: September 04, 2007 - 01:48:19 PM »
that tool is for front wheel drive cars, and the tool locates on the inner fender area.
Offline Grundy
« Reply #4 on: September 04, 2007 - 02:13:44 PM »
It wont work for a RWD?
« Reply #5 on: September 04, 2007 - 04:17:02 PM »
Yup, just set it right on the fender tops. Of course this was a car that was still destined for body work, so I wasn't too worried about any scratching or denting. I did not notice any obvious denting from doing so, but I suppose that would be possible depending on weight supported and the actual body lines it is sitting on.
Offline Grundy
« Reply #6 on: September 04, 2007 - 04:21:58 PM »
Well.. i suppose You could use 2 bars, and some good neoprene padding underneath.. then for a 340, you're talking about 600lbs (approx) on 4 corners, that's 150 lbs each. I think it would be ok.
« Reply #7 on: September 04, 2007 - 04:26:33 PM »
I used it with the I verticle so it was two contact point about 2.5 wide across the width of the fenders. I did this witha 360 automatic. I suppose a 4x4 wood block may work as well as absorb somesurface iregularities, but again, there is that weight thing.
Offline Got JOB
  • Member since 2-14-06
« Reply #8 on: September 04, 2007 - 07:02:13 PM »
Ther was a tech article in Mopar Action a couple years ago that showed using a piece of angle iron and supporting the engine with the carb studs and they dropped the k frame out of an A body to do repair work on the lower control arm stud.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline Grundy
« Reply #9 on: September 05, 2007 - 08:52:31 AM »
Found 2...
http://bernardembden.com/xjs/enginesupport
http://www.moparfins.com/clairdavis/K.htm
They're both made from wood, which is probably acceptable for short term use, but I wouldn't go with anything less than (2) 2x6's.
