Author Topic: i've come to the end of my rope--340 won't run  (Read 2951 times)
Offline snipernuts
« on: September 04, 2007 - 08:04:31 PM »
hi guys!! i've got a 1969 SE Charger, survivor car. we origionally pulled the 318 in it, it was tired, and dropped a 1972 340 from a Challenger in it, with a therma-quad
problem---at first it would vapor lock so bad it would just stall, put a electric fuel pump in and a spacer and mopar electronic ignition, no that was solved.
but when it get hot, if you just lightly touch the pedal, it acts like it wants to stall, and sometimes does.
it will stay running in park and neutral all day...until i bump it into gear, it stalls,
could it be jetting (.95) or the metering rods (don't know the diam) or????
i need some direction, can anyone help...please!!!
thanks!!
greg
1964 Plymouth Sport Fury Con't 426 wedge
1965 Mustang Conv't
1969 Dodge Charger SE 340
1970 Lemans Sport Conv't 400
1970 Dodge Charger R/T
Re: i've come to the end of my rope--340 won't run
« Reply #1 on: September 04, 2007 - 08:15:33 PM »
probably not set up correctly on the idle circuit ..here is a comprehensive article that may help you  http://australianfordhardtopclub.org/Carter_Thermoquad_info.htm
« Reply #2 on: September 05, 2007 - 02:12:01 AM »
ther could be a lot of problems , vacuum leaks internal carb issues , timing set wrong , damaged torque converter
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #3 on: September 05, 2007 - 10:57:52 AM »
Like Chryco mentioned, are there any vacuum leaks?  Is the idle high?
Was the carb recently rebuilt?  If not, that might be a place to start as rebuild kits are obtainable for as low as $19 (or atleast when I rebuilt mine a couple years ago.) from Autozone.  I like to start from scratch sometimes and go with the prcess of elimination.
« Reply #4 on: September 05, 2007 - 11:01:15 AM »
check the float level too
Offline Street_Challenged73
« Reply #5 on: September 05, 2007 - 11:57:29 AM »
I'd lean more towards the torque converter failing.  My old '69 Charger with a nicely built 318 had the same issue you've described with yours.  It would run awesome while in neutral, but as soon as you put it into gear & hold the brake pedal, it would start to choke itself out until I was able to get on the gas.
Offline IMNCARN82
  • LeDZeP
« Reply #6 on: September 05, 2007 - 03:27:48 PM »
 :iagree:   I'd go for the torque converter...  just saw the same thing happening in a 70 superbee vert. His bro built it,never ran right. Now you should see the grin on his face. ;D
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline snipernuts
« Reply #7 on: September 06, 2007 - 10:46:57 AM »
hi guys! Some great starting points to go to!! i do know the vaccum is good, we did the smoke test. electrical is good, it gets great spark.  but, we will have to check float levels, and definately the torque converter, i didn't even think of that!! the car still has the 904 tranny from the old 318, i have a 727 on standby.  i'll post what we come up with this weekend.
i  apprecaite all the ideas you guys posted, this is great!!
thanks!!
greg
1965 Mustang Conv't
Offline moper
« Reply #8 on: September 07, 2007 - 01:05:01 PM »
HAve the carb rebuilt by someone who likes Thermoquads if it hasnt. It sounds like a simple carb issue to me. Whether that can be fixed by you, you know better than I. Check the step up pistons (the rod hangers). Check that the secondaries are truely closed. If there is slop in the trottle shafts, you need to have that addressed. How is the PCV system? Power brake booster if you have one? The Tquad is very sensitive to vaccum leaks.
Offline matt63
« Reply #9 on: September 07, 2007 - 01:35:10 PM »
Beg, borrow,steal another carb that is known to work properly so you can determine if it is carb related.
Matt in Edmonton
'68 Valiant
Offline ntstlgl1970
  • T a c o c a t
« Reply #10 on: September 07, 2007 - 07:37:05 PM »
 :iagree: with CP, moper and matt 63. See if you can check or substitute another carb first. Even if you have to spend $10 at pick and pull (I don't know where you live but there are always plenty of t quads around here) for another carb to test it, it's a helluva lot cheaper and easier than swaping a torque converter/transmission.
You say the vacuum is good, what does it read exactly? 10, 15, 20 inches? Steady?
Block all the vacuum ports so nothing is connected to the carb, and intake, retest. When/if it wants to stall, try closing the choke butterfly and see if it runs better/smoother.
Is the base gasket good? as in take the carb off and physically look at it. no tears or missing layers?
Make sure the vacuum advance for the distributor isn't connected to manifold vacuum also.
Hopefully you aren't trying to run this thing on some old gas, cause that will do this also.
