Author Topic: Ideal MIG welder set up for body work... What to use? What works best? HELP!  (Read 2803 times)
Offline Lunchbox
Re: Ideal MIG welder set up for body work... What to use? What works best? HELP!
« Reply #15 on: September 07, 2007 - 01:38:56 AM »
Oh yeah another thing I learned to help with welding is if your two pieces that you are welding together are the same thinkness, it will save a headach or two.
I buy my sheetmetal form www.onlinemetals.com You can get it in small panel sizes then most places offer local (where I live minimum is a 4x8 sheet) I also get different thicknesses, such areas like the cowl can have different thickness due to the factories stamping process.
Lunch
Offline Chlngrcrzy
« Reply #16 on: September 07, 2007 - 10:24:46 AM »
Lunch
What is your preference in thickness and metal type for patching in rust through on roofs?
Offline Lunchbox
« Reply #17 on: September 07, 2007 - 10:48:40 AM »
I haven't done anything with the roof yet. But with the cowl, I will cut the affected metal out then I will Mic (Micrometer, old habit I use a caliper) the clean edge, then I use the sheetmetal I have with the closest thickness.
Lunch
Offline MyMopar
« Reply #18 on: September 07, 2007 - 11:46:14 AM »
Some good info here.  I use the Miller 175 also but have done a lot of axle bracket welding and such so I haven't done any thin stuff yet.  I'll p/u some 20 gauage to see what happens.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
