Reading through a variety of topics here, I often see guys buying parts for a premium price from Year One or Paddock that are still available from Chrysler. Since I was a reseller once, I had put together a list of OEM parts that were still available. This list is several years old so prices may not be accurate and some of these parts have gone NS1, which is dealer speak for discontinued, but they may be in inventories at different places around the country that dealers can search for. Also, some things are not exact replacements, like the E body door handles which are slightly different for Cudas than for Challengers, but most of these will work without much drama.
The list is long so I'll post it in multiple replies, but here it is.
part num description price
4797146 A/C dryer $67.75
5010125AA ATF DEXTRON 3 1 GAL $12.50
4383441 backing plate-brake-support-left 11x2.5 drums $77.50
4383440 backing plate-brake-support-right 11x2.5 drums $77.50
4173447 balancer- A engine engine cast crank $180.00
2951673 balancer- A engine steel crank $340.00
2265938 bearing-clutch torque shaft, 4 required all models $2.25
2405077 bearing-throwout assy 10-1/2" clutch $77.10
2265656 bearing-upper, steering column 66-71 all models $20.10
6033795 bolt- square head battery terminal a/m $1.70
6023092 bolt-attaching A engine windage tray 4 req $2.25
6035462 bolt-flexplate to crankshaft, all models $1.70
6030536 bolt-flywheel all engines $13.75
6036207AA bolt-harmonic balancer-A & hemi engine $5.50
6029799 bolt-self locking shifter plate $2.85
6029713 bolt-timing cover A engine $2.95
3491296 bolt-U, rear end 6-5/8" long $11.30
0220800 bolt-viscous fan bolts 4 req $2.25
6026919 bolt-w/washer trans housing dust cover all models $7.00
6027865 bolt-w/washer transmission to engine, 4 req all engines $2.70
6024863 bolt-w/washer-engine to trans/bellhousing 2 req all engines $4.50
3515300 boot-clutch fork bellhousing $14.45
2269214 boot-lower balljoint All V,L,B,J,R,W,X Models $8.20
2996454 boot-shifter 4-speed 68-70 B body w/console $67.10
2950074 boot-shifter 4-speed 68-70 B body without console $72.00
3467766 boot-shifter 70-74 E Body, 71-74 B body Square hole $65.95
3467764 boot-shifter A body 4-speed $68.25
2835896 boot-tie rod end $6.35
3402575 boot-torsion bar '73-up B, X, S. E T R-body $12.75
2071173 boot-torsion bar rubber boot all models exc imperial & c body $17.20
2269127 boot-upper ball joint all models exc A & Y body $9.50
2951834 bracket-A engine alternator mounting-non A/C $7.00
2951747 bracket-A engine pwr steering 1970-79 $17.00
3880999 brake-rear T and hose assy 70-74 ABE body $48.95
53030254 breather-valve cover single outlet round gold colored $10.01
5216050 bumper-glovebox door hinge-E body $1.70
2535027 bumper-lower control arm rebound A Body $18.45
2784714 bumper-rubber hood leveling-rear corner-all models $4.10
2276804 bumper-rubber leveling-fender extension to hood $2.20
4014050 bumper-upper control arm all models $6.95
2801724 bushing-A833 4-sp & 727 AT tailshaft $9.10
3575333 bushing-AT linkage-rubber 1974 & up. All models $2.50
3575434 bushing-AT trans linkage-used from 1961-96 on all models $2.00
2269709 bushing-C body sway bar $12.00
1940725 bushing-rear shackle-all A Bodies $4.95
1400269 bushing-rear spring shackle-all models exc A body $3.75
2071204 bushing-upper control arm 67-72 B body, 70-74 E body $16.75
2884730 cable-heater temp control 70-74 B,J,R,W $25.00
2983778 cable-negative battery 70-72 B/E body all engine, 70-72 A body $14.10
4450615 cable-negative battery V8 , H N $30.20
4294951 cable-parking brake equalizer, all 1970-71, exc 71 B/E body $4.60
2770662 cable-positive battery 68-73 A body A engine $123.00
3764166 cable-positive battery 72 B body A engine $28.75
2983649 cable-positive batteryc 70-1 E body 71-72 B body B-RB engine $28.35
4897646AA cable-speedometer, A, B, E body 1966-74 $38.45
3769123 cable-throttle A engine 360 4bbl, fits 74 up w/ 360 $44.50
2899339 cable-throttle-68-71 383-440 engine, B body $49.00
3418839 cable-throttle-overall length is 23". 70-74 E Body, 71-80 B Body $38.45
2889785 cable-trans to cruise control servo 1967-1981 models
2880829 cam-canceling-turn signal switch $121.00
4315764 camshaft-thrust plate A engine $6.50
3580894 cap-front wheel bearing cover 72 & up all models $7.25
1613416 cap-front wheel bearing, all models exc 9' brakes up to 1972 $7.25
52079880AA cap-radiator all models 64-91 $9.50
2497500 cap-windshield washer reservoir a/m $2.45
2951544 choke well cup B-RB engine $28.95
2951545 choke well cup gasket, B-RB engine $3.25
4343950 clamp-A engine distributor $4.20
4041606 clamp-A engine silicon bypass hose $4.50
2892399 clamp-speedo drive pinion adaptor housing all models 64-89 $3.70
3454220 clip-door handle to latch rod-70/71 V,L,B,J,R,W,X,P,D,C $2.50
3454221 clip-door handle to latch rod-70/71 V,L,B,J,R,W,X,P,D,C $2.50
2405049 clip-fender seal or cover on inner fender $0.95
6023285 clip-retaining for 3418899 & 2418900 throttle cable stud $0.95
2201467 clip-retaining, emergency brake rear cables a/m $2.10
1838508 clip-spring, distributor cap hold down all Chrysler distributors $1.75
2217508 clip-window belt w/s outer/inner all V,L, outer only all BJRWX $0.25
2892263 clutch-pivot fork B-RB-Hemi engine B,J,R,W models $26.05
2461765 clutch-torque shaft pivot engine side $21.25
2461766 clutch-torque shaft pivot frame side $46.70
2495531 coil-ignition all engines/models $42.10
5211126 connector-windshield washer hose All E & 71+ B Body $2.95
2204728 converter-door drain, 727 all models $1.45
3575303 coupler-steering column 73+ R,W 65-73 full size Chry/ply/dodge $84.10
4443436AC coupler-steering pot rebuild package $9.25
6028750 coupler-steering roll pin $1.75
3748263 coupler-steering shaft $9.95
3748310 coupler-steering shaft C body w/tilt-tel $9.95
2843892 cover-bellhousing inspection A engine 4-speed $45.25
3751249 cover-goes in place of air tube on exhaust manifold,1975& up A/B/RB engines $10.45
3769964 cover-timing A engine 69-79 $154.00
2899530 crankshaft-oil slinger, all engines $6.75
2964116 decal-roadrunner deck lid 70-71 standing bird $20.75
4022410 decal-roadrunner running bird rt side 68-78 Roadrunner $17.20
3749059 decal-roadrunner-Standing bird w/helmet 73-74 Roadrunner $13.70
4874000 differential-sure grip additive $5.25
4202951 dip stick-oil level indicator 904 & 727 trans exc Hemi $9.45
2466302 dipstick-auto Trans oil level all models 904/727 $9.45
3698500 dipstick-B-RB HP engine 1970-71 $10.20
2899246 dipstick-B-RB motor 1968-9 $10.00
3656738 distributor-pick up & plate V8, 72 & up electronic ignition $24.45
3656862 distributor-reluctor, all V8 electronic ignition $7.50
1122532 dowel pin-engine to trans locating pin 2 req 0.500 diam $1.85
