I had removed the spring and checked for the retainer hitting was ok .Guides had been cut down for teflon seals.I could spin the valve with the air pressure off ,seems to be seating ok and not bent .I did measure max lift the valve was opening and hold it down for full revolution of the crank .There was a slight hit but I couldn't really tell when it was in relation with the cam lobe- piston position ,I was turning it with the starter under the hood ,so I'll have to get my son to help and turn by hand. Had roller rockers and tried 273 type also.
