Author Topic: B-Body rear end on E-Body..???  (Read 13836 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: September 06, 2007 - 01:13:41 PM »
You talk a lot of B-Body rearends on E-Body..
Will a B rear, spring brackets, fit straigth on an E-body, just by using 1" relocater kit..???
nivvy
Re: B-Body rear end on E-Body..???
« Reply #1 on: September 06, 2007 - 04:01:47 PM »
If you talking about the spring perches all you need is the mopar 3/4 relo kit and the springs will match up perfecT to the b body spring perch... trust me on this as I did it....dont look for other ways on this forget about the extra 1/4 on the 1" kit...
B body rear and 3/4 relo kit / 10" wheels and 5" backspace....period!
pm me if need more details! I fit 28*12.5*15's easily whith no wheel spacers...and plenty of clearance to the spring and wheelwell lip...
 :2thumbs: but I am going bigger soon.... :burnout:
« Last Edit: September 06, 2007 - 04:06:00 PM by StrOkEr »
Offline 360 'CUDA
« Reply #2 on: September 06, 2007 - 08:34:56 PM »
I already posted on this thread earlier today but it got deleted somehow  :dunno:  Maybe because of the system going down several times today.
Doesn't matter because I saved it.......
Yes,  But you need A-body springs
When viewed from below the stock springs on a E-body go right through the wheelwells wasting about 3/4 inch.  With a sixties style B-body rear, Super Stock spring hangers and springs you kill two birds with one stone.  Better traction with tire clearence and it's all a bolt in  :2thumbs:
Of course you can use any A-body springs like the HD ones if you don't want to go with SS springs
Get a Mopar Performance Chassis book.  They are cheap and very helpfull  :ebay:
« Last Edit: September 06, 2007 - 08:37:04 PM by 360cuda »
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #3 on: September 10, 2007 - 04:20:11 AM »
SORRY....  :bricks1:
I ment to write:    ....
Why can't I use the E-Body springs... :clueless: :clueless: :clueless:
« Last Edit: September 10, 2007 - 08:51:33 AM by cowboy »
« Reply #4 on: September 10, 2007 - 07:13:26 AM »
If you conver to the SS spring hanger, you can use A body springs or super stock springs. Both are the same length. However, you cannot use B body springs in an E body. They actually are different lengths than E body springs.
Offline ArcticCuda
    • Pepe
« Reply #5 on: September 10, 2007 - 07:33:28 AM »
I have '67 Belvedere rear end and I use Dr Diff hangers with E-body springs. With this set up I can use 10x15" wheels with 5" back spacing.
If you have 68-70 B-body rear -> 5.5" bs is the best choice.
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #6 on: September 10, 2007 - 08:52:46 AM »
SORRY....
I ment to write:    .... :bricks1:
Offline ShelbyDogg
« Reply #7 on: September 11, 2007 - 12:22:45 AM »
YOU CAN USE E-BODY SPRINGS.
I made my own 1" offset front hangers and rear 1" offset shackles, dropped in a b-body rear end, then used the 10" wheels with a 5-1/2" backspacing.  Dr Diff sells the offset kit, then all you would need is the rear-end.
« Last Edit: September 11, 2007 - 07:37:46 AM by shelbydogg »
Offline 360 'CUDA
« Reply #8 on: September 11, 2007 - 02:53:16 AM »
For better traction you may consider using A-bod springs.  They have a 2" shorter front segment that reacts better to clamps and other mods. The shorter in the front the stickier the launch it seems to me.
Not a big deal but any little thing you can do to plant the car better helps.
Offline 360 'CUDA
« Reply #9 on: September 11, 2007 - 02:59:17 AM »
I made my own 1" offset front hangers and rear 1" offset shackles, dropped in a b-body rear end, then used the 10" wheels with a 6-1/2" backspacing.  Dr Diff sells the offset kit, then all you would need is the rear-end.
Did you mean 5 1/2" backspacing? Because even 5 1/2" is pushing the limit
Offline ShelbyDogg
« Reply #10 on: September 11, 2007 - 07:37:19 AM »
Whoops, I changed it.   Yes 5-1/2 backspacing is what I'm using with the 10" wheel. It all fits inside the wheelwell and it sits LOW.
Offline Morris'_Mopars
« Reply #11 on: September 11, 2007 - 09:55:20 AM »
X2
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
Offline vinb
« Reply #12 on: September 11, 2007 - 07:27:32 PM »
I used a B-body 8 3/4 housing and 440/6pk B-body springs that I modified in my '72 Cuda stocker years ago. They worked out great, avg. 1.52 60ft times in a 3650lb. small block. Where talking back in the early 80's, OK,  360cuda I know they weren't legal for Stock Eliminator, but then again who was.. :grinyes:
« Reply #13 on: September 11, 2007 - 08:50:33 PM »
Yeah, but they were more legal that a pair of straight up super stock springs. I know about the main leaf substitution trick and have it on my Aspen. It ran 1.70 60 footers right out of the box.
Offline Carlwalski
« Reply #14 on: September 11, 2007 - 09:54:11 PM »
:iagree: I test fitted some cop rims on Dad's Cuda a while back. 15 x 10" with a 5-1/2" BS and it fit perfectly. Close but not close to hitting. It had roughly 1/2 an inch to the lip and around 1/2-3/4 of an inch to the leafs.
:2cents: :wave:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
