Author Topic: How_to_convert_Ebody_non-Rallye_dash_harness_to_Rallye_dash_harness  (Read 635 times)
Offline trouble
« on: September 06, 2007 - 08:03:46 PM »
How difficult is it to convert non rallye dash to rallye dash ?
Offline buzzard
  • Why is their AIR
Re: How_to_convert_Ebody_non-Rallye_dash_harness_to_Rallye_dash_harness
« Reply #1 on: September 06, 2007 - 09:02:16 PM »
 It's realy not that hard but if you dont have all the part it could be pricey. If you are after A/C some parts are rare and expensive. I think most of the rest can be had at resonable cost. Good Luck
Offline EvilTwinATX
« Reply #2 on: September 06, 2007 - 11:05:18 PM »
Here is what you need:
1. Rallye Gauge Cluster and Bezel
2. Rallye Switch Cluster and Bezel
3. Rallye Light Bar (4 lights instead of 3)
     Note: This is NOT interchangeable with non-rallye bar. Not Repopped
4. Rallye A/C Switch and Bezel
     Note: Not Currently Repopped. The switch is SQUARE, whereas non-rallye has a "cut" corner. Bezel does not      have an indention and it's smooth, not ribbed.
4. Rallye Radio DIN Bezel
     Note: Only difference is that the Rallye bezel is smooth, not ribbed. Not Repopped either.
5. Rallye Cluster Wiring harness.
     Note: A Correct wiring harness is repopped and avail from Year One, but is not necessary. www.rt-eng.com makes a simple adapter harness to turn your non-rallye into a rallye harness. (Ask for Greg)
Greg at rt-eng.com also sells alot of the items you need.
As for price... if you have nothing expect to pay anywhere from $1000-1500 for correct stuff before you are all done.
Hope this helps! I have all my stuff together.... finally... but it took me a while.
