Author Topic: Plug Wires - Pre-made or Cut your own? Favorite Brands?  (Read 3153 times)
Offline longgone
« on: September 06, 2007 - 11:14:23 PM »
Wanting some new plug wires for my 70 Cuda 440-6pack.  Few questions:
1. Do most people buy pre-made for their motor or buy universal kits and cut their own?
2. If you cut and crimp your own, are the $30-40 crimpers worth buying?
3. What brand/type is your favorite?
 :feedback:
Thanks
Blueglow
Offline gkring
Re: Plug Wires - Pre-made or Cut your own? Favorite Brands?
« Reply #1 on: September 07, 2007 - 01:02:11 AM »
I always roll my own and the MSD crimpers are a must for the best crimps. I've found off brand crimpers at local swap meets. The interchangeable jaws work great with weatherpack and Deutsch connectors as well. I usually buy the MSD 8.8 by the roll and the connectors in the 100 pack. For single sets buying a cut to length set is a much better deal.
Greg
1970 Barracuda driver
« Reply #2 on: September 07, 2007 - 12:25:57 PM »
I buy universal kits & cut to length , typically I use Moroso Blue Max or MSD wire sets
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: September 07, 2007 - 07:44:29 PM »
I've had good luck with moroso and msd cut to length wires also. The fitted sets always seem like they are sized too long on a couple of wires. Pliers are nice to have but not absolutely necessary. I think you are going to get about 50 opinions on plug wires here. Just make sure you get a good quality wire and route it correctly away from heat and abrasion sources and you should be fine.
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #4 on: September 07, 2007 - 09:31:40 PM »
I always use Accel pre-made. I always had problems with the cut your own kind.
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« Reply #5 on: September 07, 2007 - 09:59:58 PM »
I like the Taylor cut-your-own wires. What I really like about them is the snap-type connector on the plug end of the wire. No way is that plug wire gonna get loose from the plug. That's why I switched to Taylors - periodically a plug wire or 2 would loosen up and actually fall off completely from the plug :swear:, and then the car would run like sh*t. And there's nothing quite like trying to re-connect a spark plug wire with a hot engine, is there?
 Anyway, there's my :2cents:
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Offline vinb
« Reply #6 on: September 07, 2007 - 10:32:28 PM »
MSD 8.5 mm universal super conductors, comes with the cutter & crimper tool. All you need is a vise....
Only Black or Red wire , Gray boots...Summit or Jeg's approx. $70.00......
« Last Edit: September 11, 2007 - 07:10:27 PM by vinb »
Offline Autophile
  • Kowalski... and the keys to a sawed-off weekend!
« Reply #7 on: September 08, 2007 - 04:02:55 AM »
I use MSD 8.5mm wires (cut to fit), MSD wire shielding, and heat shrink over the shielding-to-boot interfaces.
1971 Cuda, black/black, 419 cu. in. 3G Hemi with twin turbos (build in progress), AlterKtion, Wilwood 12.19" disks, billet Rallye wheels
Offline 440Charger
« Reply #8 on: September 11, 2007 - 02:54:52 AM »
Now that is a clean engine bay.  Nice work  :2thumbs:
Those wire lengths look perfect..those were pre-cut?
I love my 440...but it's not loving me back...yet
Offline moper
« Reply #9 on: September 11, 2007 - 12:41:28 PM »
Taylors or MSD. I like to terminate/crimp my own.
Offline Autophile
« Reply #10 on: September 11, 2007 - 12:52:53 PM »
Thanks! I cut the wires to length.
Offline go-fish
« Reply #11 on: September 11, 2007 - 03:44:52 PM »
Once again, nice work Autophile. I usually got the yellow Accels and made my own. Get the crimping tool. Like said before it is a must.
I did go with MSD 8.5mm with the engine I'm putting together now.
There is a guy on Moparts.com, SunroofGTX, that makes wires.http://www.firecore50.com/
  If you're looking for a no hassle solution I would at least see what they have to offer. I actually enjoy a good DIY job.
