Author Topic: 8 3/4 Axles  (Read 1798 times)
Offline Kilrcuda
  • M.ostley O.ver P.owered A.nd R.espected
8 3/4 Axles
« on: January 06, 2004 - 04:51:38 PM »
I am trying to swap the center sections on my 8 3/4 rear I have the passenger side axle slide out. but on the drivers side the axle comes out about 1/4" then seems to be stuck. Am I missing something or do I need a slide hammer? Or maybe someone has a trick? Any help would be appreciated.
Thanks!!!!!!
1971 Cuda 340, auto.
Offline heminut
Re:8 3/4 Axles
« Reply #1 on: January 06, 2004 - 07:13:33 PM »
Sometimes the bearing sticks in the housing. You might need a slide hammer to pull it.
1970 5.7 Hemi Cuda
Offline keith
  • i want a new drug ...
Re:8 3/4 Axles
« Reply #2 on: January 06, 2004 - 07:29:39 PM »
mine came out no problem, there shouldn't be anything else to do but pull.
1973 Dodge Challenger
69' 383bb + holley 750 dbl pmpr
727 tran + b&m pro-ratchet
8-3/4 + auburn6 posi + 3.91
black cuda interior mod
Re:8 3/4 Axles
« Reply #3 on: January 07, 2004 - 02:52:09 AM »
carefully pry the bolt plate off the studs they will grab sometimes
Offline Kilrcuda
Re:8 3/4 Axles
« Reply #4 on: January 07, 2004 - 07:34:04 AM »
Thanks for the info guys I will try all the above. I think I will go with Chryco's advice first since it will be the easiest after that it gets the slidehammer.
THANKS!!!! :D
Offline Kilrcuda
Re:8 3/4 Axles
« Reply #5 on: January 09, 2004 - 09:27:08 AM »
Little update, after two tugs on the slidehammer the axle was out.
Thanks again for the help!!! ;D
