Author Topic: wheel stud diameters???  (Read 1112 times)
Offline HemiOrange70
« on: September 10, 2007 - 08:12:17 PM »
Car is still in the body shop. I am ordering two new cragar mags for rear and need lug nuts.....what size are studs-7/16 or 1/2"??? I know I need rh and lh threads as it is a 70. (70-318-10" drums-had 7 1/4 now 8 3/4 diff)This will save me a trip-thanks
Re: wheel stud diameters???
« Reply #1 on: September 10, 2007 - 08:13:33 PM »
1/2 inch :2thumbs:
Offline GoodysGotaCuda
« Reply #2 on: September 10, 2007 - 08:19:51 PM »
1/2x20.  70 i believe is a LH thread on the drivers and RH thread on the pass. However, make sure that diff you swapped is in fact a 1970 before going through with that...
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: September 10, 2007 - 10:28:39 PM »
 :bigsmile:
Offline 360 'CUDA
« Reply #4 on: September 11, 2007 - 03:09:20 AM »
Why not go with aftermarket 3 inch long 1/2" 20 wheel studs?  If your studs aren't sticking into the head of the lugnut at least 1/2" you might have strength issues because some of those Cragers are pretty thick.
If you don't like the way open lugnuts look you can always cut down the studs a bit but you don't want studs that are too short
« Last Edit: September 11, 2007 - 12:55:13 PM by 360cuda »
